vward9
- April 26, 2015
- Connecticut
- 96 Ford Explorer Limited
I have been having problems with my 1996 Ford Explorer limited Edition's window's and door lock's. I have been told that the Master control panel switch need's to be replaced. I don't think that is the case because I can hear the motor and switch click whenever I hit the lock/unlock switch on the master control panel. Also all windows being controlled from all the other door panels will only work from the master panel. The left side lock/unlock door on the master panel only works for the passengers rear left side door, the right side doors will not lock/unlock at all. May I add when I am using my remote the same applies to all the door's except the trunk and rear left passenger door. What is going on here, someone please help. Tired of using a key entry.
