Won’t shift into over drive only 96 ford ranger | Ford Explorer - Ford Ranger Forums - Serious Explorations
David Carnahan
Dundas,Ontario
96 ford ranger xlt
Hi their I have a 1996 for ranger and and I’m having an issue with it going into overdrive was working fine last night and then now it’s not wanting to go into over drive, it will shift from the first 3 gears np at all and won’t go into overdrive only. The fluid is fine checked that and when I looked underneath at the pan their is no visible leaks did find wiring harness for the transmissionand it’s very dirty, should I try and clean that? It will hit 3000 rpms doing 80 and higher if I go faster what’s could cause this issue?
Mike65
Location
In my garage working on one of our vehicles.
Horsepasture, Virginia.
00 Ranger 4x4, 99 Sport.
David, welcome. Are there any warning lights that are on?. You might want to go to a local parts store & have them hook up a scanner & see if there are any codes in the system.
RichnMo
Ozark, Mo.
1997 Explorer Limited
You might pull the plastic surrounding the ignition key and tumbler area as my 97 explorer had a similar issue where it wouldn't go into OD. When I took that plastic off you could see the wires coming from the button in the shifter were worn through and no longer making contact. I repaired them and good as new ! Good luck I hope this helps
RangerX
Elite Ranger
Staff member
Moderator
Omao, Kauai
'93 Ranger XLT 4X4
Do you have the 4.0, 3.0, or 2.3 engine?
