Won't move after changing trans fluid | Ford Explorer - Ford Ranger Forums - Serious Explorations
63falcondude
Toms River, NJ
2000 Ford Explorer EB
I'm stumped. Drained the transmission fluid, removed the filter, and pulled out the valve body to replace the gaskets. Replaced the filter and trans pan gasket then put 4 quarts of Mercon V fluid in.
Now when I shift into reverse, drive, 2, 1, or 4WD it doesn't move. I can push it when it's in Neutral. Any ideas?
drdoom
VA
2005 Eddie Bauer 4.6L 4X4
Are you certain that you engaged the manual valve pin upon reassembly? Also which engine? I assume V6, so with a Valve Body drop, you are looking more in the neighborhood of 7 quarts. Another possibility is missing filter o-rings.
SoNic67
Newport News, VA
2001 V8 (Eddie Bauer) AWD
The filter needs to be perfectly sealed into the receiving cylinder.
Basically if you scratched the bore when you removed the old plastic ring or if you didn't install correctly the new ring, the pump it will "suck" air via that bypass, instead of oil.
63falcondude
Toms River, NJ
At first I didn't and I couldn't move the shifting lever at all. I fixed that.
4.0L V6 SOHC
Haynes Manual says 4 quarts.
63falcondude
Toms River, NJ
I installed the o rings on the new filter. Is the filter supposed to snap into place?
drdoom
VA
And you have the 4x4 filter I assume? So a pan drop is 3.5 quarts, and VB drop you will need at least a couple more quarts for that. I seem to recall needing 7 to do VB gaskets, but I may be confused. The filter pushes in, and of course the center bolt keeps it in.
63falcondude
Toms River, NJ
Pretty sure it's the 4x4 filter. I'll check to make sure. I held the filter in place and bolted it through the center. Maybe I didn't push it in hard enough? And I'll just have to double check the fluid specs.
63falcondude
Toms River, NJ
I am reading on other threads that people use around 7 quarts like you said. There is between 4-5 quarts in mine now and fluid is a good 12" or so up on the dipstick. I let it run for about 10 mins but can't drive it to heat it up how it should be to test.
63falcondude
Toms River, NJ
I used the bolt from the original filter instead of the supplied bolt. Could that be a problem?
SoNic67
Newport News, VA
AT fluid is measured with engine running, because when internal pump is working, the level in the pan drops.
If you have the same level between engine off and running, then the pump is not sucking oil from the pan.
63falcondude
Toms River, NJ
Okay that's good to know. I will have to check the filter to make sure it is on there good. Thanks, I'll post what I find out.
63falcondude
Toms River, NJ
Fixed! Had to add more fluid. Thanks guys.
SoNic67
Newport News, VA
Glad that you came to post back the result!
