Big-E
- December 19, 2010
- Holiday, Florida
- 1997 XLT
Hey all,
97 XLT 4.0 SOHC 4 x 2 - 183,000 miles
This am it was dumping rain in TampaBay Florida and my truck didnt want to go over around 1500 rpms. As i turned around to go home I hit a puddle and it got a bit better. Hit the gas and she ran up to 3k no issues then stopped. I know i have a sensor issue. On the drive to work it would cycle between reving out to 2000,2500, or 3000 rpms when ever it wanted to. This is in gear under load so it should not hit a limiter but it seems it's runing in limp mode. I do have the check engine light on but I think its due to bad intake gasket (slated to change vavle cover gaskets this weekend and intake gaskets.
I have owned this truck for the last 120,000 miles and this is the 2nd time this has happened. The 1st time i replaced the CAS sensor and it corrected it. I am thinking this could be AFM or TPS.
Any ideas?
Also if anyone would like to take a stab at it, since about 95,000 miles the O/D light will flash on and off on the dash in random. Hit a bump.. it will flash.. then stop 10 mins or whenever it wants later. Had tranny serviced around 100,000 k per the manuel.
Thanks Again,
Eric
Any ideas?
Thanks Again,
Eric
