BeautyBoo69
- July 25, 2022
- Albuquerque
- 2002 Ford Explorer XLT
I have a 2002 Ford Explorer XLT and it starts perfect but it won't shift into gear
does it have manual 1/2?I have a 2002 Ford Explorer XLT and it starts perfect but it won't shift into gear
Honestly I don't know what that isdoes it have manual 1/2?
usually from left to right on the shift indicator its PRND21. the 2/1 is manual engagement, which uses different solenoids. do those work?Honestly I don't know what that is
so youve tried 1 and 2 manual? sounds like a low pressure issue.No I think its stuck in neutral
You need a windows laptop and an elm327 adapter with forscan so you can see your trans pressure or any codes that are storedNo I think its stuck in neutral
^^^^knowledgable fellow right here, and ditto on what he saidYou need a windows laptop and an elm327 adapter with forscan so you can see your trans pressure or any codes that are stored
Thanks buddy i try to keep my thinking cap on but sometimes it wanders off from time to time^^^^knowledgable fellow right here, and ditto on what he said
all good, soemtimes mine just vanishes too especially when i first wake up!!! no shot at even having a thinking cap then!Thanks buddy i try to keep my thinking cap on but sometimes it wanders off from time to time
Yeah, when I wake up mines gone too, I have to go and find it its usually hiding from me because I have a lot of dumb ideasall good, soemtimes mine just vanishes too especially when i first wake up!!! no shot at even having a thinking cap then!
same here, my peak is maybe 2 pmYeah, when I wake up mines gone too, I have to go and find it its usually hiding from me because I have a lot of dumb ideas
possibleI'm stuck in a different town right right now and don't have much to use do you guys think it could be the selenoid
Yes it doesDoes it have fluid in it..?
