TheFord
- April 25, 2021
- FL
- 2004 Ford Explorer XLT
I have a 2004 Explorer XLT. Began having intermittent problem of not going out of park. And, the tail lights stayed on when car was parked and no key in ignition. Without knowing it until it was too late, the tail lights drained the battery. I changed the brake light switch. Then, after charging the battery and even having someone try to jump start, it won't crank or turn over. The dash lights up, radio and AC come on, mileage is still there and not zeroed out when key is turned but car does not click or try to crank. I've had no trouble with starter or any other troubles. I unplugged battery to change the brake switch. There is a red light on dash in center that blinks at a regular pace which has always been that way. I've never done any changes to the system or etc. I just click button on key dongle to unlock and drive away. One thing I did after battery went out and it was charging was I used the actual key in the door lock to open the drivers door because there wasn't enough battery to use the button on the push button dongle to unlock electric locks. Since them, I have put key in doorlock to lock and unlock in case it rests anything.
Also, I have noticed the anti-theft light flashes steady as normal but when I put the key in the ignition it begins to flash rapidly.
Any suggestions what I should check? Thank you.
