shelbydog25
- January 5, 2008
- Winchester, VA
- 2004 Eddie Bauer
My 04 wouldn't start this morning. 60K miles. It has had some intermittent starting issues, meaning on occasion it would crank, but not start. then for a few days it would start as usual, and run great.
today, it just cranks, but won't start. anyone give me place to start to look at. fuel pump? (I believe I hear it engaging when the key is turned in the run position.. I will check again tonight). fuel filter was replaced 2 mos. ago and no rough idleing. when it starts, it runs great.
It also sounds as though the starter solenoid is engaging. All cranking seems normal. daughter said on some occcasions after a "hard start", and it started, the "gauges got all wacky" and the diagnostics window had to recheck itself. PCM issue?
