RICHARD/MN
- March 24, 2009
- ROCHESTER, MN
- '91 SPORT 2WD
Hello to all. I have a 1991 sport 2wd. I need to locate the wot relay. I've located 3 relays directly below the fuse block. Which of the three is the wot relay? Also, if anyone can tell me the color code of the wires that connect to the coil of this relay.
I am trying to diagnose an a/c compressor drop out problem and locating this relay will help.
Thank you
Thank you
