how can mpg cause engine failure? if anything youll run out of gas. fill er back up and done. or
read the fuel gauge east enough to see when youve got 1/4 tank left so you can pull into a station to refuel. how will mpgs affect the temps it runs at? if anything it would just aaffect the fuel pump temps from lack of lubrication from fuel. perhaps i am missing something, though. who told you it runs hotter than normal? the only reason it would run hotter is if youre on the gas alot towing above the max rating, then it may be out of range, but who says its hotter than it should be? todays engines run lots hotter than old ones. also if you dislike the sun visor, maybe velcro it? not too sure on that one. sorry, im just finding it a bit hard to understand how mpg affects temps, and how the engine is "secretly" running hot
