Originally posted by clarkkent
if i'm spinning at a higher rpm then i was at 3.73, especially on the highway, doesnt that mean im wasting more gas going the same speed as i was with the 3.73?where does the saving gas come in then?
The gas savings comes in when the new lower gears(higher number) allow your engine to run in its most efficient rpm range (usually 70-80% peak torque. If you add larger tires to a otherwise stock truck you move the engine out of its operating range. Gears can bring it back where it belongs.
Likewise if you add a cat back exhaust and a TB, say an open air filter and move the torque peak up a couple hundred RPM if you were geared high to begin with you may move the engine out of it operating range.
You cant do everything well, you need to ID how you drive and what you want to do. If you want mileage- you sacrifice for acceleration, which trades off top speed, which trades off rock creawling, which trades off around town driving, etc
In your case 3.73s would give you great top speed, highway mileage should be ok on the flats , may suffer if you have lots of hills. Around town milage will be down, and away from a light you will be sluggish.
4.56s should get you off the line decently, around town mileage would be back to around stock I would bet, and highway may be down slightly at the extreme top end, but pretty good at moderate speeds. Offroadability (low speed control) will be good.
Also as a general rule a vehicle with a manual trans needs more gear than a similarly equipt vehicle with an Automatic trans. So an Auto with 4.30 may have some of the same low speed properties as a manual vehicle with 4.56's.
just some impressions.
From what you said with a stock (only bolt ons) engine I would think the 4.30s like Alec suggested would be for you- the 4.56s if you paln on lots of off pavement - but 2wd is limited in mud - even locked up. I doubt you would notice much with the 4.10s going from 3.73s
Good Luck
