X-Spec Lowering Kit Installed...
I Can Defy
Worcester, Massachusetts
2001 ZX3
Just so you know- we're dealing with 1998 X's...
OK. I got an X-spec lowering kit for free, with the special Edelbrock IAS lowering shocks. The person who gave it to me kept the X-spec sway bar however, so I got to drive one X with the whole deal, then one X with the whole deal but with a factory rear sway bar. First off- the kit is great, especially with the special IAS shocks. HOWEVER, if you are gonna do this- GET THE X-SPEC REAR SWAY BAR! I mean, in a neccesity sense, you don't really NEED it, but when you have that in there with this kit and these shocks- the thing sticks to the road like glue and stays flat too! SWEET! So, total time for install was LENGTHY-partly due, however, to the fact that i had to do 2 trucks at the same time (switching out factory suspension stuff form mine for the lowering parts form his). Let me just say- when all you've got are hand tools, suspension rust is THE ENEMY! The total project took me about 16 hours to do. So, about 8 hours per truck- not bad. The most pain in the ass part was getting the new front alignment cams positioned and tightened- you have absolutely ZERO space to fit sockets in there because of the brake/fuel/trans lines. Otherwise, the biggest time consumer was carefully taking off rusty bolts so as not to break them. Then finally, took it to get an alignment.
Now- this is where i have a question for anyone who could answer- what are the chances that a well reputed Sears auto-center would misalign my front end? Here's the deal- it drives perfectly straight...so technically, it's 'aligned'. BUT, if you stand in front of the vehicle with the steering wheel straight, the tires turn outward ever so slightly...is this an optical illusion? or should i get it checked? I'm just worried about uneven wearing on my $700 tires! ANYONE WHO COULD ANSWER THIS- PLEASE DO!
In closing- I would reccomend this kit to all. yes, it's a little pricey from EE- so if that's an issue to you, and you want to do it the 'autozone way'- just buying blocks and U-bolts, i reccomend the X-Spec sway bar and special Edelbrock IAS shocks. If anyone is going ot try lowering their truck like this- feel free to ask me any questions...i learned a bunch of tricks that go against the conventional instruction that make stuff a lot easier. I will have pics soon so you can see the difference between stock and lowered.
Eric
PS-IF ANYONE HAS AN X-SPEC 1998 REAR SWAY BAR THEY WANT TO SELL, EMAIL ME!!!:bounce:
Join the Elite Explorers for $20. Gets rid of the ads!
james t
Moderator Emeritus
Texarkana AR/TX
94 SAS sport
yes, you will have to get it aligned. it will eat up your front tires, and just because it tracks straight doesnt mean it doesnt need alignment. just drive it for a few months and you will see what im talking about.
I Can Defy
2001 ZX3
i'm sorry james- i should have been more specific. let me try this again-
after installing the kit, i took it to the local well-reputed sears auto center for alignment. they performed the alignment, and i drove it home. BUT-what are the chances that they would misalign my front end? Here's the deal- it drives perfectly straight...so technically, it's 'aligned'. BUT, if you stand in front of the vehicle with the steering wheel straight, the tires turn outward ever so slightly...is this an optical illusion? or should i get it checked? I'm not sure...they guarantee their alignment for 60 days, but I don't know how to find out if it's properly done or not- i don't want to have to spend any more money...PLEASE HELP.
Eric
aldive
Elite In Memoriam
1999 XLT
I Can Defy
2001 ZX3
The X-Spec kit said to have them align it to these specs:
Camber- .5-0 degrees negative
Caster- Maximum Possible
Toe In- 1/16"
So I gave them that, and they said that's what they did. Help? :rolleyes:
Eric
aldive
Elite In Memoriam
1999 XLT
I am not sure that you got a good aslignment. Take it back and have them put in on ther "machinr" and see the numbers yourself. If they balk, Sears has a Satisfaction Guaranteed policy, get your money back and go elsewhere.
Keep us posted.
I Can Defy
2001 ZX3
they gave me a print out-
left:
camber: -0.1
caster: -3.0
toe: 0.07
SAI: 11.7
right:
camber: -0.1
caster: 3.5
toe: 0.08
SAI: 11.8
front:
cross camber: 0.0
cross caster: -0.5
cross SAI: -0.1
total toe: 0.15
Any help from that?
Eric
james t
Moderator Emeritus
Texarkana AR/TX
94 SAS sport
ahh... okay. i misunderstood you. mine is lowered 2" and IS aligned to spec, and i know that if you look at it from front veiw down the side and compare the front wheels to the rear the fronts lean in slightly. and i mean VERY slightly. not many people notice it when i ask them to look at it. mines ok. i also noticed when i put my stock wheels/tires back on a while back (for a long trip) that it is not noticable at all with them. something about more wheel/less tire makes it more noticable.
aldive
Elite In Memoriam
1999 XLT
I Can Defy, did you use the EE bump stops when you lowered your Explorer?
If not, did you do anything to the stock ones?
Thanks.....
I Can Defy
2001 ZX3
james t- thanks for the info...i'm gonna go back and have em check it again, and i'm gonna watch. my question for you is this- even with that little bit of turn-in on the tires, do they still wear evenly?
aldive- I just kept the factory bumpstops. the only time my x bottoms out is with 5 passengers and even then it's rare. the only thing i may do to the factory bumpstops is drill out the center of them, which is basically all the EE ones are- same size as factory ones, but with a hole cut out of the middle to allow them to 'flex'.
Eric
james t
Moderator Emeritus
Texarkana AR/TX
94 SAS sport
yea, they are wearing evenly. like i said, the negative camber (tires/wheels leaning in) is BARELY noticable, but i do notice it as some of my friends. i have about 10k miles on my drop/wheel/tire combo right now. when i checked them a couple of weeks ago with a tire wear thing (i cant think straight right now) they are wearing evenly.
I Can Defy
2001 ZX3
where did you get the tire wear guage?
eric
james t
Moderator Emeritus
Texarkana AR/TX
94 SAS sport
a friend who has a tire shop gave it to me a long time ago, but Autozone and other chain car/parts stores have 'em. they are cheap ($2-5).
X24
RAMajama
Pleasant Valley, NY
05 RAM 2500 TURBO DIESEL
Personally, I very much dislike sears auto. I have had nothing but problems with them. One time, I proved the mechanic wrong and he started yelling at me. Heh, that was fun when I told his manager. I said "I dont like getting people in trouble but this guy deserves to lose his job." The manager took my advice. :D I have heard of places doing half assed allignments... because most people cant tell the difference. Who's to say that they didnt do it right if they didnt get a print out. 5K down the road is too late to go back with a complaint when your tires wear out. My mechanic told me which places he knew did real alignments and which places to stay away from. Mine doesnt pull right anymore and the wheel is straight when going straight now. I could tell by looking at the front that some major inprovements had been made. I love the way it handles now!!!!!!
I Can Defy
2001 ZX3
so where'd you go for your alignment???
eric
aldive
Elite In Memoriam
1999 XLT
Ask around and see what locals say. I personally like to find a local tire store with very expensive alignment equipment.
I too would avoil Sears .
Good luck....
X24
RAMajama
Pleasant Valley, NY
I was recomended to a privately owned goodyear dealer. When I went to drop it off the night before they told me everything they were going to do. They said that they were going to leave it in the shop overnight (which made me happy) and that they would start work around 10:00 and finish around 12:00. They were very nice. Sometimes you just get the feeling that they know what they are doing.
R X-Spec Suspension Owners Lowered Explorer - Ranger Suspension Tech 3
Turdle My EE X-Spec testimony Lowered Explorer - Ranger Suspension Tech 1
R Explorer Express X-Spec Suspention Lowered Explorer - Ranger Suspension Tech 5
S X-Spec Suspension Kit Lowered Explorer - Ranger Suspension Tech 10
R x-spec suspension Lowered Explorer - Ranger Suspension Tech 13
C Lowering my 91 explorer Lowered Explorer - Ranger Suspension Tech 0
B Lowering torsion bar HELP Lowered Explorer - Ranger Suspension Tech 13
B Lowering blocks install question Lowered Explorer - Ranger Suspension Tech 3
K Installed lowering keys... now leans to the right Lowered Explorer - Ranger Suspension Tech 4
M Lowering 2nd Gen - Front Bump Stops Question - also shocks ? Lowered Explorer - Ranger Suspension Tech 1
M Lowering 2000 Limited with rear air supension - Ride Height Calibration Question Lowered Explorer - Ranger Suspension Tech 0
S Lowering 2000 explorer Lowered Explorer - Ranger Suspension Tech 2
N Lowering 04 Explorer 4x4 Wagon Lowered Explorer - Ranger Suspension Tech 4
R Lowering Shackles Lowered Explorer - Ranger Suspension Tech 12
1 Advice needed about lowering blocks! Lowered Explorer - Ranger Suspension Tech 6
L Lowering a 2007 Explorer Lowered Explorer - Ranger Suspension Tech 0
J 98 explorer sport lowering blocks question Lowered Explorer - Ranger Suspension Tech 1
H Details on lowering kits for my 99' Mercury Mountaineer Lowered Explorer - Ranger Suspension Tech 5
8 lowering kits for 2nd gen explorers? Lowered Explorer - Ranger Suspension Tech 5
E Canuck Motorsports lowering springs installed Lowered Explorer - Ranger Suspension Tech 0
D Lowering quick struts. Lowered Explorer - Ranger Suspension Tech 1
R 02 XLS Lowering for performance, not looks. Lowered Explorer - Ranger Suspension Tech 0
S Lowering the front end. Lowered Explorer - Ranger Suspension Tech 2
9 1st gen x lowering help Lowered Explorer - Ranger Suspension Tech 2
A lowering the 2nd gen 4x4 Lowered Explorer - Ranger Suspension Tech 4
J Lowering my Explorer. Lowered Explorer - Ranger Suspension Tech 6
S lowering front and back w/ a week in between. Lowered Explorer - Ranger Suspension Tech 0
A Lowering Explorer Lowered Explorer - Ranger Suspension Tech 1
F lowering factory control arms? Lowered Explorer - Ranger Suspension Tech 7
A 01 lowering kit????? Lowered Explorer - Ranger Suspension Tech 8
DeadlySteve Lowering Gen 1 4x4 ... Lots of Q's! Lowered Explorer - Ranger Suspension Tech 3
S Lowering an 05 AWD V8 Mount Lowered Explorer - Ranger Suspension Tech 1
U Lowering a 98 Mounty 5.0 AWD. Any help appreciated! Lowered Explorer - Ranger Suspension Tech 3
F need help lowering a 1997 4x4 Lowered Explorer - Ranger Suspension Tech 4
D Lowering a 2001 Sport Lowered Explorer - Ranger Suspension Tech 8
F lowering ?s Lowered Explorer - Ranger Suspension Tech 8
P Lowering via Torsion Twist Questions. Lowered Explorer - Ranger Suspension Tech 3
O Lowering my 99 Sport Explorer. Lowered Explorer - Ranger Suspension Tech 2
T Lowering my 00' Mounty. A few questions... Lowered Explorer - Ranger Suspension Tech 7
R please help! lowering 06 explorer/mountaineer Lowered Explorer - Ranger Suspension Tech 4
9 New Sticky Needed :TT Lowering the front Lowered Explorer - Ranger Suspension Tech 1
O Will I need an alignment after lowering blocks? Lowered Explorer - Ranger Suspension Tech 4
D Lowering first Gen Explorer. Lowered Explorer - Ranger Suspension Tech 28
O Lowering blocks...what is the actual drop? Lowered Explorer - Ranger Suspension Tech 3
R Lowering 2002 XLT Lowered Explorer - Ranger Suspension Tech 1
O Lowering 2003 Ford Explorer Sport 4WD Lowered Explorer - Ranger Suspension Tech 5
B Lowering keys Lowered Explorer - Ranger Suspension Tech 34
A lowering first gen 4x4? Lowered Explorer - Ranger Suspension Tech 11
B Finally the time has come.... lowering. Lowered Explorer - Ranger Suspension Tech 5
M Lowering a 3rd Gen Lowered Explorer - Ranger Suspension Tech 4
Similar threads
