X Sport (mono leafs) and lowering ride quality with rearend sag? | Ford Explorer Forums - Serious Explorations
jsun
Calgary, Alberta, Canada
99 Explorer Sport SOHC 4x
Hey gang,
I've searched this forum and it's not that easy, so I'm asking those with experience for advice.
I have been considering dropping the X using the EE lowering kit, but have been contiplating on the right set up.
My Q is: With the mono leafs already sagging, should I switch these out to the four door leafs before I drop the front end using the torsion method? How does this rear end sag effect overall rearend ride quality???
I would rather get the front and back levels set correctly then adjust the allignment, before I realize that the monos handle like crap.
Thanks in advance!
J
I would first start with the EE lowering kit. Install it in the front. Then if you are not happy. You can do the rear or swap leafs with a 4-door.
Thanks Matt!
But my real concern is with all my repairs lately I can not afford to do a allignment twice. I would much rather get this right the first time of attempt.
I guess I have questions aimed at you since you truley have the experience with this. I have read most of your write ups of your web site and may have missed this.
Before you lowered your X using the methods mentioned on this forum and your site....Did you suffer from the sport sag in the rear before you made your lowering mods??? If so, then I assume all is well. I really dont want to effect the ride quality in the rear if I do not replace them due to the "sag".
Also, do you know if the 4 door leafs will affect the rear ride hight by a dirrect swap from the mono leafs? Meaning...will I have to re-allign my torsions to achive correct ride hight all around?
Thanks man...I'm just tired of putting money into this truck and all I have acheived is repairs and exterior mods:rolleyes:
BTW...I think your ride is pimp!
Cheers... J
You could always do a ghetto alignment yourself and eyeball it, to see how you like the height.
True...but....I want a good quality ride from the rear as well. The sagging of the monos is my real concern here. After I drop this truck will I suffer from poor ride quality? Am I better off just switching out the monos to a "real" leaf set-up???
Thanks man!
J
