XLT 98' no 4x4.... just another thead...
jmvb
1998 Explorer XLT
Well, I found in the worst way that my 4x4 is not working
in the last weekend travel to the Chilean mountains, as never before, I suffer with some easy off road tracks.
I finally went stuck, and just with the previously installed winch, a stock lift jack and my wife help, I could go back.
The dashboard lights turn on in hi and low mode, I can hear the transfer motor working (was changed new recently), but I'm pretty sure that the front train is not driving.
If I engage the LOW, the torque difference is noticeable.
For some reason, the transfer clutch is not engaging.
Where should I start to check?
96eb96
Albany, NY
96 EB V6 OHV 4WD
If you can download http://forscan.org/download.html, use an OBDII adpater, read the GEM codes, it will give us clues where to look. Maybe a bad speed sensor? You can check resistance of both sensors and report back.
jmvb
1998 Explorer XLT
Hi 96ag96
I have a scanner, but I have no codes so far and no check engine light on...
BTW: what sensors do you mean?
96eb96
Albany, NY
96 EB V6 OHV 4WD
Can your scanner read GEM codes? Check engine light has nothing to do with 4x4. The link I gave you can read the 4x4 computer and do tests. If the lights blink, you very likely have codes.
There are two sensors in your transfer case - an input and output speed shaft sensor.
They share wiring with the shift motor. There is also a brown wire that controls the clutch that gives 4x4. The way the system works is the more different the two sensors are in speed the more current the brown wire gets (and that powers the front axle).
If a sensor is open or shorted, you would lose 4x4 and get a code.
96eb96
Albany, NY
96 EB V6 OHV 4WD
Yes, apply voltage manually and see what happens. If it works the switch or sensor is bad. In your case check for voltage (96 is a bit different, I don't have a 4hi, just auto and 4 low).
jmvb
1998 Explorer XLT
How can I apply the voltage manually? you mean, apply to the brown wire? how many volts?
jmvb
1998 Explorer XLT
Today, I put the explorer in the air, the 4 wheels lifted
Engaged the 4 hi, gear in 1, all wheels moving....
Engaged the 4 low, gear in 1, all wheels moving fine also... WTF!!
We take the explorer to a unpaved road
4x2 and full gas, the rear tires slip a lot
4x4 HI + full gas, the truck out very fast, no slip at all
4x4 LO + full gas, the truck out like a rocket!
WTF!!!
I have proof that the front wheels didn't do anything the last weekend
Any clue?
Mbrooks420
High Voltage.
EF Vendor
1998 Mountaineer AWD
The TOD (torque on demand)clutch used to slip in my 96 when it was worked hard. It made a clicking sound, however.
Mbrooks420
High Voltage.
EF Vendor
I used to drive long distance on no winter maintenance roads. Sometimes 10 or more miles long, and with deep snow in the winter, and heavy mud when it thawed. If we made several trips down, or it was particilarly bad the clutch would slip inside the transfer case ( that allows for the "automatic" 4wd function). It is electromagnetic and cycles as the truck detects wheel slippage. In low the clutch locks the front and rear axles together. In low, only one front tire will spin under load, due to the open differential. Both back tires can drive, depending on which rear axle you have. When it slipped, It would make an audible clicking sound, and the front drive would become jerky.
jmvb
1998 Explorer XLT
Ok, that would explain why in the shop, with the engine and transfer case relative cold, the 4x4 works fine and why in the mountains, with about 2 hours of climbing road and 30 minutes off road, engine and transfer hot, the TOD clutch do slip.
Now, how can I repair it?
Mbrooks420
High Voltage.
EF Vendor
Can you hear it clicking? It was fairly obvious. Unfortunately, it might be cheaper to replace the case.
jmvb
1998 Explorer XLT
Mbrooks420, no I did not... I just don't have front wheels drive after a while to medium- hard off road..
J New member 95 Ford Explorer XLT 4x4 4.0 window wiring Stock 1995 - 2001 Explorers 5
E 01 Explorer XLT 4x4 4.0L. Need Advice for my Jungle Medicine Fix... Stock 1995 - 2001 Explorers 2
W Emergency brake, 97 Explorer XLT 4x4 SOHC Stock 1995 - 2001 Explorers 24
J 2000 Ford explorer xlt 4x4 Stock 1995 - 2001 Explorers 2
B 98 4x4 XLT Stock 1995 - 2001 Explorers 4
J Looking at a 1996 Ford Explorer XLT 4x4 Stock 1995 - 2001 Explorers 7
I 96 XLT 4X4 automatic not engaging gears. Stock 1995 - 2001 Explorers 2
D Assessment of my cost of ownership - 2001 XLT 4x4 V-6 SOHC Stock 1995 - 2001 Explorers 14
L '97 XLT 4x4 Modes: What am I Actually Getting? Stock 1995 - 2001 Explorers 10
T 1995 Explorer XLT 4x4 for Sale Stock 1995 - 2001 Explorers 0
M Stock Size Tire Rub 2001 XLT 4x4 Stock 1995 - 2001 Explorers 9
R 99 XLT 4X4 4.0 bogging down, loss of power Stock 1995 - 2001 Explorers 1
R 99 XLT 4X4 4.0 bogging down, loss of power Stock 1995 - 2001 Explorers 3
N Walking Dead - 1999 Explorer 4x4 XLT (174K) - PICS Stock 1995 - 2001 Explorers 135
K Shocks 2000 4x4 xlt - help choosing Stock 1995 - 2001 Explorers 8
J '96 Explorer XLT V6 4x4 Idle.. Oh my! Major issue! HELP Stock 1995 - 2001 Explorers 0
J '96 Explorer XLT 4x4 Electrical Question Stock 1995 - 2001 Explorers 0
J 1996 Ford Explorer XLT 4x4 Rear Bumper Stock 1995 - 2001 Explorers 3
J '96 Explorer 4x4 XLT ABS System Issues Stock 1995 - 2001 Explorers 7
nugrapeman2 Wanted Looking for a 1999 Explorer XLT 4x4 or AWD Bright Red Exterior Stock 1995 - 2001 Explorers 1
T Flat tow? 1995 XLT Control Trac, AT, 4x4 Stock 1995 - 2001 Explorers 8
N mexican guy needs help with 4x4 explorer xlt 1996 front lockers dont work Stock 1995 - 2001 Explorers 1
B 1996 explorer xlt won't engage 4x4 Stock 1995 - 2001 Explorers 8
Sedition Black Tranny Fluid 1998 xlt 4x4 5R55E Stock 1995 - 2001 Explorers 12
J Just bought '99 ex xlt 4x4 4.0 sohc has usual need fixing Stock 1995 - 2001 Explorers 2
O Correct height spec for '01 XLT 4x4? Stock 1995 - 2001 Explorers 1
Z 1999 Explorer xlt 4x4 - towing it across the country, need advice. Stock 1995 - 2001 Explorers 11
T '97 explorer XLT 4x4 4.0L V6 Stock 1995 - 2001 Explorers 13
J 1997 4X4 XLT Explorer Stock 1995 - 2001 Explorers 7
S 97 Exp. XLT - 4x4 won't turn on - Need help Stock 1995 - 2001 Explorers 0
C 2010 Mustang 4.0 SOHC to 99 XLT 4X4 Stock 1995 - 2001 Explorers 3
E 98 SOHC Enigine swapped in 97 XLT 4X4 WONT START PLEASE HELP!! Stock 1995 - 2001 Explorers 7
L 2000 Explorer XLT SOHC 4x4 auto has no first gear Stock 1995 - 2001 Explorers 1
J CV joint/axle replacement on a 1998 XLT 4x4. Stock 1995 - 2001 Explorers 2
T I need a 1995 explorer 4x4 XLT 4.0 trans Stock 1995 - 2001 Explorers 0
B Front end noise on a 1995 Explorer 4X4 XLT. Stock 1995 - 2001 Explorers 8
T 95 Explorer 4 door 4X4 XLT Stock 1995 - 2001 Explorers 0
A Brake issues with 97 Explorer XLT 4x4 Stock 1995 - 2001 Explorers 20
D 1996 Ford Explorer XLT 4x4. Air bag code # 12. Stock 1995 - 2001 Explorers 1
D 1997 Explorer XLT 4x4 speed sensor problem? Stock 1995 - 2001 Explorers 0
B 99 xlt popping cracking when 4x4 Stock 1995 - 2001 Explorers 6
C 2000 explorer xlt 4x4 ( esl) Stock 1995 - 2001 Explorers 2
M 2001 Ford Exp XLT 4x4 lighting probs Stock 1995 - 2001 Explorers 0
D 2000 XLT 4x4 battery issues Stock 1995 - 2001 Explorers 5
1 96 4.0 xlt 4x4 auto hub bad ? Stock 1995 - 2001 Explorers 4
B 96 xlt 4x4 problem Stock 1995 - 2001 Explorers 6
A 96 xlt 4WD with a flashing 4X4 light. Stock 1995 - 2001 Explorers 2
X Need a lil help to put a engine in my 98 xlt 4x4 Stock 1995 - 2001 Explorers 2
D 1999 xlt 4x4 troubles Stock 1995 - 2001 Explorers 2
H 99 XLT 4x4 Under Dash Squirrel Stock 1995 - 2001 Explorers 0
Similar threads
