If you are not concerned about the power why not look at a new ST Line. It has the ST trim but the 2.3For me, I’m wanting to get leather seats and really love the overall look of the ST. The power would be nice, but I’m not as worried about that part.
Why with premium fuel? I have an ST and I never put in premium fuel. 87 regular is what ST needs.Get what you want but the Sport Appearance Package has all the appearance of the ST. Plus honestly I like the carbon grey painted pieces than black anyway. Get the ST if you want but you are probably not going to like the 17-18 mpgs you are going to get and filling up with premium fuel sucks too.
regular is what the ST will take. however, for max performance, iirc it took 91+, more so in hotter climates. also its got twin turbos, etc. imo, if you get the ST, get the full boost out of itWhy with premium fuel? I have an ST and I never put in premium fuel. 87 regular is what ST needs.
eventually your vehicle will go BOOM, ethanol and low octane is not the friend of any turbo engine. Ever.Why with premium fuel? I have an ST and I never put in premium fuel. 87 regular is what ST needs.
really? i see no issue with it, it will just detube itself to prevent knock. thats all octane is, measure of resistance to knockeventually your vehicle will go BOOM, ethanol and low octane is not the friend of any turbo engine. Ever.
i see! yep, still in school, so youve been doin this much longer than i!!!Yes, really. I have been into turbo motors probably longer than you have been alive. Turbos are great power adders but ethanol is not there friend. I have had to clean out intake runners, core exchange turbos, replace EVAP/ EGR stuff as well. It tends to gunk up but you don't have to run it all the time. As long as the plugs and air cleaners are changed you can run 1 tank of premium per 4 tanks of fill ups. It just will help clean the system out, Yeah you should also run the heck out of it on occasion. My Raptor sounded like a machine gun till I put it in sport mode and do a couple of full throttle pulls. That will help blow the gunk out and make the vehicle run better. Turbo HIpo motors tend to like to be ran hard.
Same applies to the 2.3 . 87 is fine, but use a tanke of 93 at least once in a while if not all the time.regular is what the ST will take. however, for max performance, iirc it took 91+, more so in hotter climates. also its got twin turbos, etc. imo, if you get the ST, get the full boost out of it
but dont all the major ones meet that top tier standard, or is that not enough? i know the shell v power one has got more detergents than normal. didnt know that there were more detergents in 91, wil have to look mroe into that.Just sayin'
On the left coast, Top Tier Premium Fuel (91 octane) has a much larger quantity of the very important detergent additive package than low grade 87 and mid grade 89. That's part of the higher price when compared to lesser grades.
In this environment of Gasoline Direct Injected engines - the detergent package in high grade fuel is a very important "maintenance" item.
Some old guy witty phrases refuses to die like: "you can pay me now OR pay me later..."
Carry on -
intersting.. will have to keep that in mind for the newer DIT vehicle... LA gas prices are hard to swallow as is, let alone 91Three grades, three MINIMUM additive package standards.
Premium Fuel from TOP TIER manufacturers such as ARCO, BP, Valero, Shell, Chevron, 76, Phillips 66, Exxon, Mobil, have at least the minimum amount required for each fuel grade.
I live next to the big 4 Martinez refineries and have many neighbors that work there - that's how I get my insider info - trust me
Lots of old wife's tales in this thread. Any modern computer controlled engine will see no benefit from running a higher octane fuel than the manufacturer's specs. All you do after that is waste money. And any of the major brand fuels have the same additive packages regardless of whether it's 87,91, or 93 octane. I've run turbo motors over 150k on nothing but 87 otcane pump gas and never had a problem.but dont all the major ones meet that top tier standard, or is that not enough? i know the shell v power one has got more detergents than normal. didnt know that there were more detergents in 91, wil have to look mroe into that.
