mcompton1973
- June 22, 2003
- Walnut, IA
- dunno yet
ok, I did a search, and I am not sure that my prob is a blend door problem. Maybe something else. Here is the deal. When I turn the heater to High Heat, and full blast fan after the truck has been sitting a while (like first thing in the morning, or when leaving work) it will start to get warm inside, and then for some reason it will start blowing out really cold air...it will do this for a couple minutes, and then back to heat. It may do this once or twice, but then the heat will work fine. It seams like it might be going cold on me if I get stuck at a stop light, and then start warming up again after I get going a little bit....but I am not sure of that. it only happens a couple of times a day, so proving that therory is tough.
I thought blend door was just all the time cold. What else could it be? any ideas?
thanks.
thanks.
