ExFordTech
- October 10, 2014
- 01 RANGER
Ok a little history. I'm retired but active and my neighbors Ranger broke down in front of my dwelling. So nice guy that I am looked into the concern, chain laying outside of the drivers side valve cover seams to be a concern. Pulled engine and tore apart to inspect. replaced all broken and worn parts including all exhaust valves on drivers side head. Used Cloyes timing chains at first but Rock Auto sent discontinued items and I had a concern after instillation, A link cap fell off in my hand. went back with OEM. anyways all together, timing correct and started her up and the engine runs great except for one hell of a noise from the timing cover area. Removed cover to find the side of primary chain riding up against the tensioner mounting plate. measured the thickness of the plate against the original and from the mounting base its 0.110. this extra thick bracket even though it is a redesign and heavier duty it is causing me great frustration since the chain is contacting. Has anyone else had this same concern. This engine does not have a balance shaft and is not the original engine but it is a pre 02 engine. Tomorrow I will go to my old dealer match up tensioners to see if there is differences. but anyone ever have this concern. Also I all ready checked crank end play and the thrust is within specs for the crank and cam. thrust plate for cam and the journal are also within specs.
