Years An Models Compatible With 01 Sport Trac??? | Ford Explorer - Ford Ranger Forums - Serious Explorations
    Right now you can purchase an Elite Explorer membership for $20 and receive a two year membership!
    If you have an existing Elite membership contact me by PM and I will upgrade your account manually.
KelleyC83
Kentucky
01 ford expl.sport trac
Have 01 sport Trac needing parts such as rack & pinion, gas tank, 4 wheel drive an maybe rearend. What years an models have compatible parts for it?
05dakotatrac
Ellsworth AFB, SD
05 sport trac 4X4
long story short for direct fit match for match 01-02 trac is your best bet for the suspension/drivetrain.
as for cross compatability per part you mentioned
rack and pinion: 95-01 4 door explorer/mounty, 01-03 2 door explorer sport, 01-05 sport trac
gas tank: 01-03 sport trac (21 Gallon), 95-01 4 door explorer/mounty (21 gallon)
four wheel drive (transfer case, and front axle components):
01-05 sport trac, 01-03 2 door explorer sport, 95-01 4 door expo/mounty
rear end:01-05 sport trac, 95-01 4 door expo/mounty, 2 door expo sport
catch with the rear end is your rear end is drum for a one for one swap use those years list and find drums if you're couragous go for the newer rear ends with discs.
KelleyC83
Kentucky
Will a 01 explorer sport gas tank work?
OffTrac
Dublin, GA
'01 Sport Trac 4x4
There are two rack and pinions for the ST depending on whether it is Job 1 or 2. Not sure how that relates to the Sport but it does matter.
KelleyC83
Kentucky
Yea I've found that out already, same with oil filters. U got my 6/01 model then the 9/01 models an certain parts r different which is stupid lol
