maggie922
- February 7, 2016
- The Bluegrass State
- '02 Mounty 4.6, RWD
I did a little forum searching but didn't find exactly the answer I needed.
I have a '95 EB, and until recently, I'd only had to use the factory bottle jack for minor lifting (oil change, etc) and not on a fully flat tire -- the only time I'd had a flat tire was somewhere I had access to a heavy-duty shop jack. Cut to a couple of weeks ago, when I came out of work at midnight to a completely flat tire. Imagine my surprise when I dug out the jack and the stupid handles that for some reason live behind the back seat, only to find that with the flat tire, the jack is too tall to fit under the car. Aaaaaand the scissor jack from a coworker's car (admittedly, a jack for a Camry, but I was not in a position to be choosy) didn't lift high enough. After much bad language and growling, we had to resort to an astonishingly unsafe combination of both jacks on some non-regulation jack points to lift poor Josephine up enough to change the tire.
So now I'm planning this 2500 mile road trip for next month, and I would like to acquire the One Jack to Rule Them All that 1) doesn't weigh just as much as it lifts, 2) doesn't take up too awful much space (fitting in the bottom of the plastic tote that also totes the collection of fluids required to keep a 21 y/o vehicle in tip-top shape), and 3) doesn't cost as much as the car itself. It can be a floor or scissor or bottle jack, as long as it has the proper clearance.
Also, should I be worried that EB's came with 16" wheels but the spare is a 15"? Should I be on the lookout for a 16" wheel and used tire?
