manimal
- June 27, 2006
- Gig Harbor WA
- 96 XLT
I've gone through most of the threads on pinging here, but I decided I'd ask anyway. I have a '91 OHV 5-speed here with 100K miles on it. Runs very strong, pulls great all the way to redline. The problem is that it will ping heavily while going uphill under heavy load, or at WOT.
Facts:
- EEC passes KOEO and KOER tests with code 11.
- Spark plugs were replaced with Autolites, gapped correctly. None of the old plugs looked oily.
- I'm not losing any oil, as far as I can tell. I usually do 4,000 miles on a change of Mobil 1, and I've never seen the level drop on the dipstick during that time.
- Fuel filter was replaced.
- Fuel pressure tested to be at 45PSI, pressure stays consistent (rises slightly) throughout the throttle range.
- Bought the vehicle used from a well reputed Ford dealer, and they held the vehicle from me for several days while they claimed to be replacing the lower intake gasket. I'm starting to consider checking with them to make sure that they actually did replace the lower and not just the upper. Haven't tried tightening the bolts yet, started to go at it today but realized I wouldn't be able to get my torque wrench in there without taking the hood off. Maybe?
- MAF was cleaned with electrical cleaning spray. I also have a spare MAF that I tried, but no difference.
- TPS was replaced. Not calibrated yet.
- Tried "misting" the engine with a 12oz bottle of water through a vaccuum hose.
The pinging is especially bad at WOT. Under load at mid throttle or above, the pinging is sporadic, but at WOT it is out of control. This led me to believe that the TPS may have dead spots in its operating range. Just today I was fiddling with it, and unplugged the TPS. With the TPS unplugged, the truck does not ping at all, even at WOT. I gathered that this meant that the sensor was bad, and so I replaced it. No change, and so I'm at my wit's end here and asking for any tips.
The only thing I can think of that I haven't replaced that may be of interest is the spark plug wires. They looked pretty good when I did the plug job, but I may replace them soon enough.
Also, how often is the coil the culprit? I may do the coil malfunction test, but I haven't done that before and I don't know how much of a PITA it is.
Thanks ihn advance for any tips!
Facts:
