yostyexplorer94's 1/2 Ton Axle Project | Page 2 | Ford Explorer Forums - Serious Explorations
This is the solid axle swap thread.
Specifications!
Axle
  • 1979 Full Width Dana 44 Front F150 Axle
    • Yukon Gear 5.13 Reverse Cut
    • Spicer 1310 Pinion Yoke
    • Detroit Locker 3.93 and up ratio
    • Spicer 5-760x Solid U-Joints
    • Chrome Moly 4340 Front Axle Set Lifetime Warranty Yukon India Made
      • Full circle clips - grainger - DSH-30ST PA. Item #5DU29
  • Ford 8.8 Rear Axle From a 1989 f150
    • Yukon 5.13 R&P
    • Detroit Locker
Suspension
  • Stock Radius Arms extended with 48" of .25" dom
  • BC Bronco 6.5 Lift Springs
  • Ballistic Fab Coil Mounts & Retainers
  • Ballistic Fab Track Bar Mount
  • Rear Antiwrap Bar
Steering
  • 1 Ton Steering from Ruff Stuff
    • Tie rod end stud threads are 7/8NF 18
    • Knuckle tie rod boots - Energy Suspension 913119G
      • Drivers Side Drag Link - ES2027L
      • Passenger Side Drag Link - ES2234R
      • Drivers Side Tie Rod - ES2234R
      • Passenger Side Tie Rod - ES2233L
  • 1 ton tapered GM tie rod insert to flip the steering on top of the knuckle. #TRE-63
Wheels
  • 15x8 3.5“ backspacing
  • 17x8 4.25" backspacing
Width of the dana 44 with 37x12.50r17 and 17x8 4.25 backspacing wheels is 78.25“ outside the front tires.
nice job. glad to know someone else out there is rocking almost an identicle setup as me.
My only complaint is my trac bar isn't level, when i flex it pulls the axle over a couple of inches... but it has not caused any issues so I am not gonna get to excited.
I bought ballistic fab over the knuckle tie rod inserts back in 2010/2011. This is the clearance I have between the tie rod end and the knuckle.
I overall love the inserts and haven't had any real problems with them other than I clearance for the tie rod boots. (they rip off within 2 turns of the wheel)
I ordered the same tie rod flip inserts so lets install these in my spare knuckles.
1" hole.
Let's not have this issue again. I countersunk the inserts in the knuckle to give me more clearance.
Sweet, right? Sure.
All kinds of clearance now.
Too much clearance.
If I would not have countersunk it, It would have been perfect. That's what I get for assuming the product is the exact same from 7-8 years ago and not actually comparing them side by side. At least I should be able to run a boot of some sort.
They ended up tighter than planned. I am very glad I countersunk them
The boot installed. We shall see if it holds up.
