- February 8, 1999
- Wayoutin, Aridzona
- '93 XL '20 ST
- Callsign
- AB7FH
Ford to extend recall on 4.0L engine
Published: 18 April 2001
Posted by: Robert Lane
Courtesy, Blueovalnews.com
Ford Motor Company will extend the engine warranty on all 1997 and 1998 Ford Explorer and Mercury Mountaineer vehicles built with a 4.0L SOHC engine for the front cam chain guide assembly.
The additional coverage program will be in effect for 7 years from vehicle warranty start date or 100,000 miles, whichever occurs first.
The program will now include all 1997 and 1998 model year Explorer and Mountaineer vehicles with 4.0L Single Overhead Cam (SOHC) engines built at the Louisville Assembly Plant from July 29, 1996 through October 20, 1998 and at the St. Louis Assembly Plant from May 29, 1996 through September 18, 1998.
On some of the affected vehicles, the front cam chain guide assembly may wear or break and cause excessive cam chain noise that does not go away after five minutes of engine operation.
Dealers are instructed to install a new cam chain guide assembly if the original is found to be worn or broken. If it has broken and fragments have entered the engine oil pan, dealers are authorized to clean the block of all debris, replace the engine oil pick-up and filter assembly, and install new oil and filter.
