This was so hard to do I had to change my design ideas like 3 or 4 times to get it right. The biggest hurdle was getting the 90 degree brass fittings to fit inbetween the manifold and the valley of the engine block. If you look closely at each of the 90 degree brass fittings you can see that I shaved them down on the bottom and the outer sides so that they do fit and trust me they barely fit. really a trick install. Also I didnt want my methanol to come in through the intake into the brand new rebuilt ported supercharger I had for it. The methanol would take the coating off the supercharger blades faster and then oxidation could start to show up on the blades.
