Timing Chain 5 | Ford Explorer Forums - Serious Explorations
Timing Chain 5
S
Timing Chain 5
Clean out the bolt holes in the timing cover (if you remove it). The bolt was jammed because of the build up, not bound up on the block like I thought. I used the bolt to scrape out the hole and this is what came out. I followed up with a small wire brush to make sure it was cleaned out.
Album
1997 Ford Explorer
Spudhut
Image metadata
Filename
File size
300.6 KB
Dimensions
1280px x 960px
