aldive
Elite In Memoriam
- January 17, 2001
- 1999 XLT
I hope that this is in the correct place ( I hate the new catagories ).
The rear windshield wiper on my ’99 has a devious mind of its own; it functions only when it wants to. I have long suspected poltergeist infestation and even considered an exorcism.
The rear wiper has been an adversary the entire life of my truck. First it had the infamous wipe pattern problem ( but after researching I found …TSB 15406 BACK GLASS WIPER SKIPS GLASS
APR 17, 2002 and ordered the new arm – see http://www.explorerforum.com/forums/showthread.php?p=1164355#post1164355 post # 6 ) and it has had the non-functioning wiper motor issue ( a common Explorer issue ).
I decided to bite the bullet and purchase a new rear wiper motor ( F87Z17508AD ). I ordered the motor from one of our sponsors, Ford Parts Network ( http://www.fordpartsnetwork.com/ ). The price was $117.31 with a refundable core charge of $35.00 ( minus return shipping ).
To access the wiper motor the liftgate door trim panel must be removed. To accomplish this remove the two screws under the lift handle and then with a panel removal tool, unsnap the trim and lift it up and out of the way. Prior to removing the motor, the pivot arm must be removed. This is accomplished by lifting the cover on the arm and removing the 14 mm nut and pulling the arm off.
I found than closing the liftgate and opening the rear window made it very easy to access the motor.
To remove the motor, first move the black plastic water shield out of the way to access the wiper motor, then take out the three 8 mm attaching bolts and disconnect the electrical connector.
The motor has a "made in Mexico" sticker on it ( both the new as well as the original ).
Installation is simply the reverse of the above procedure.
The total time for this project was about 30 minutes, with the removal/replacement of the liftgate trim panel was the most difficult part; those snap connectors are tougher than they look.
After buttoning up the liftgate, the wiper was checked; alas, a functioning ( at least for now ) rear wiper.
