Serious Explorations Ford Explorer and Ranger Message Board
#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
Searches ExplorerForum.com Only
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
How to: 1st Gen Explorer Heater Core Replacement Diary
Reply
Thread Tools
Old 05-12-2005, 07:20 PM   #1
Glacier991
EF Tranny Guru
Sacramento, CA 95827
1992 XLT
Vehicle Specs
Quoted: 4 Post(s)
(Original Poster)
[Preamble: Ok.. I know it is no big deal, not much harder than changing a spark plug, but ya know, we all started someplace in our auto repair, and this one is a good "starter" job for a newbie mechanic.
So.... that said, here we go:
Ah, summer, the time when a young man's heart turns to.... heater cores? Usually this time of year is when the AC threads start up, but a heater core failure is no respecter of seasons.
If you have never had a heater core failure, they often show up in a way that scares the bejesus outta ya.... a puff of what looks like smoke appears at the vents! Whoa nellie, get out the fire extinguisher! Not. The leaks usually are so ssmall they atomize antifreeze and it shows up looking for all the world like smoke or steam. Relax, well sorta relax, you have a leaky heater core. Is all. No big deal for us 1st Gen Explorer owners, as you will see.
Now the heater core is a pretty simple device, a little radiator really.... and in summer you COULD just disconnect the two hoses going to it, and using a hose connector and clamps just hook em together and wait til fall - I know, been there done that. But I decided to just go ahead and replace mine, and do a photo thread of the process.
In the years I have been doing car stuff I have replaced a "few" heater cores (including this one! More on that later) and I gotta tell you... FORD hit it out of the park on the first generation Explorers in this department. It is a very easy job, 4 screws and 2 hose clamps - that's IT. No dropping the dashboard (81 Cougar, an ALL day job) or wierd contortions to get to it.
Ok let's get at this task. The heater core is in a little chamber under the glovebox, and the hoses connect on the firewall just behind the glovebox, here:
The "box" (if you like $5 words I think it might be properly called a plenum chamber) is in 2 "clamshell" halves.. it looks like this as it just sits there:
and 4 screws hold the box together... I'll show you the first 3, the 4th is just in the back on the center hump side.. here is 1
and two
and 3
These screws are 5/16's. the back most ones need something short, a 1/4 drive socket is perfect for them. There is one more I didn;t show, it is near the back. With all 4 removed it is easy to take off the front of the "box".
Look at the AF in this one, think I had a leak?
You will notice it has a drain so it won't leak into the passenger compartment should it fail.. nice touch!
Once the front is removed, you are AT the core... (sounds like a bad sci fi movie, eh?) From the looks the leak was somewhere near centerline....
Remove the hoses (sometimes easy sometimes you need to cut them off, don't worry, you have enough extra to do that) and you have just the ends of the core tubes sticking out..
pull the core into the passenger compartment until the hose connectors clear the firewall, then down and out. EASY ! Disassembly COMPLETE !
Looking at the core, it appears this one started leaking at the top seam...
upside down
since it was less than 4 years old good chance of electrolysis (more on this later). The new one is more or less identical.
This is a place where a helper can be nice. I did it without one, but there is nothing holding the core in place but the hoses. Reinstallation is just reverse of taking it out.. carefully up then thru the firewall. A helper can apply pressure on the core while you work the hoses on. Tighten the clamps, put the box half back on and add the 4 screws, and YOU ARE DONE !
Whoever figured this one out at FORD ought to get a bonus. Unfortunately later Explorers do not have it this easy.
Now about the core. The core that went I picked up a few years at Autozone for under $20. The new one I bought at CarQuest for close to twice that. Side by side they look nearly identical. Was the Autozone one bad? Well maybe, maybe not. If a heater core fails in short order, suspect electrolysis. How to check ? Put a voltmeter probe in the antifreeze and one on the battery ground. Anything around .2 volts or higher is BAD news.
I had replaced the radiator, flushed the system and added new AF since the heater core was installed, so of course it checked out ok - NOW. But, I could have had electrolysis before. So no verdict. The Carquest core was "made in the USA". We'll see.
Anyway, now you can have heat in your Explorer this summer. In Minnesota it will be a blessing. Ok you guys in Florida can stop laughing now.
Glacier991 is offline   Reply With Quote
( Join the Elite Explorers )
Join the Elite Explorers for only $20 a year
Explorer Forum has probably saved you that much already, and will continue to save you money as you learn how to diagnose and fix problems yourself, and learn which modifications really work without having to experiment on your own. Elite Explorer members can change the forum "styles" to eliminate most ads, including the blue underlined links, and no ads on photos. Other benefits include the ability to store 1000 Private Messages, add your own avatar to your posts, upload photo attachments directly to your posts and to our Photo Gallery and more. Join the Elite Explorers today. Your support of the forum is greatly appreciated.
Old 05-13-2005, 09:59 AM   #2
85Dave
Germantown, TN
92 XLT
Vehicle Specs
Quoted: 2 Post(s)
Awesome! When you replaced either of the heater cores, did you notice any debris buildup? Leaves, dust, dirt, hair, etc?
85Dave is offline   Reply With Quote
Old 05-13-2005, 12:45 PM   #3
Glacier991
EF Tranny Guru
1992 XLT
Vehicle Specs
Quoted: 4 Post(s)
(Original Poster)
No nothing of that sort. Not sure with the Explorer setup if they could get in there in any event.
Old 05-13-2005, 12:47 PM   #4
Tony H
New York, Wading River (that's on Long Island)
'91 Eddie Bauer
Vehicle Specs
Quoted: 0 Post(s)
Easy, just like the old days. Too bad in many cars the are so buried. They go bad often enough that they should be as accessible as this.
Nice pics considering where you are working.
__________________
1975 CJ5 with fiberglass body and 350/345Hp chevy power:bought it in '79
1985 chevy stepside pickup, 300K on the clock: Original Owner
1989 Volvo 240 300K on the clock: Original Owner
the 1991 X is my newbie with 331K on the clock: bought OCT.'03 with 183K
http://home.lyse.net/brox/TonyPage4.html
Tony H is offline   Reply With Quote
Old 05-13-2005, 04:14 PM   #5
rocco123
Endicott, NY
rocco123's Avatar
1994 XLT & 2002 Limited
Vehicle Specs
Quoted: 16 Post(s)
Thanks Glacier. Another well explained article.
rocco123 is online now   Reply With Quote
Old 05-13-2005, 06:18 PM   #6
techieman33
Topeka, KS
techieman33's Avatar
00 V8 Mountaineer
Vehicle Specs
Quoted: 3 Post(s)
Nice write up, i remember when mine went it scared the hell out of me, and I was even more scared when people kept telling me horror stories about replacing the heater core's in their cars, It was a big relief when I finished in 15minutes, I just with this thread had been around then.
techieman33 is offline   Reply With Quote
Old 04-07-2006, 12:02 PM   #7
Brigrat
Humboldt, CA
93 XLT
Vehicle Specs
Quoted: 0 Post(s)
I hate to dig up an old thread, but I just inherited a 93 that is on its 4th heater core in 6 years. This Exploer is destined to be my beater trail/beach rig. I have two quetions:
1. What could cause the heater core to keep going out?
2. What would be the consequences of not having a heater core, and just connecting the two tubes together.
Winter was mentioned, but I do not live in a cold area, and I would rarely drive this rig in the Winter anyways.
Brigrat is offline   Reply With Quote
Old 04-07-2006, 12:23 PM   #8
Tony H
'91 Eddie Bauer
Vehicle Specs
Quoted: 0 Post(s)
The only thing I can imagine is Stressing the tubes during installation will cause them to fail.
Just Bypass it if you don't need it. No negative affect on the engine.
__________________
Old 04-07-2006, 08:39 PM   #9
lifeguard379
sacremento,ca
93 eddie bauer 2 door
Vehicle Specs
Quoted: 0 Post(s)
another good trick is to put the caps from the new hc in the old one befor you pull it out so you dont spill af all over your carpet. ( i found that out the hard way)
__________________
93 2 door eddy Bauer HP44 and Big bearing 9 and 4.88 My elite registry
http://www.explorerforum.com/forums/...d.php?t=153392
sas thread
http://www.explorerforum.com/forums/...d.php?t=165147
sas registry
http://www.explorerforum.com/forums/...d.php?t=244780
lifeguard379 is offline   Reply With Quote
Old 04-08-2006, 07:09 AM   #10
unclemeat
Richmond, VA
unclemeat's Avatar
91 sport
Vehicle Specs
Quoted: 14 Post(s)
This is just what I needed to see. I need to replace mine and I had bad feelings about spending a whole Saturday doing it. I may go buy a new one today. Yea ha.
unclemeat is offline   Reply With Quote
Old 04-09-2006, 12:10 PM   #11
Creager
Charlotte, NC
Creager's Avatar
'92 Sport 4x4
Vehicle Specs
Quoted: 0 Post(s)
I probably should do this also. How much do these heater-cores usually go for? $30?
__________________
Creager -
Slightly mod'd 92 sport -
4.56, TrueTrac -
3" lift, Tires -
Creager is offline   Reply With Quote
Old 04-18-2006, 10:38 PM   #12
Glacier991
EF Tranny Guru
1992 XLT
Vehicle Specs
Quoted: 4 Post(s)
(Original Poster)
Yeah around that. Brigrat, 4 cores that fast certainly suggests electrolysis. But this is so cheap and so easy why not flushand replace your coolant and then the heater core and be done with it for now? This is truly a 30 min job. Why be without heat for that little effort?
PS. Put a new 12 gauge wire from the engine to the battery Negative terminal while you are at it.
Old 04-19-2006, 04:06 AM   #13
Christobal65
Sacramento CA
92 XLT & 91 3000GT VR-4
Vehicle Specs
Quoted: 0 Post(s)
Am I the only one that had issues getting my hoses to seal on to the new heater core?
I did this about 3-4 months ago and had one hell of a time getting the hoses to seal properly. I replaced the clamps with better ones the the stock ones, cranked them down nice and tight but still had leakes...I am not sure what i did to get it to stop, but it did.
__________________
1992 Ford Explorer XLT 4x4
Factory Tow Package with Trany cooler, oil cooler and 3.73 LSD rear end
All stock with 190,000 on the clock and still running strong
1991 3000GT VR-4
335HP DOHC 3.0L Twin Turbo V-6
Christobal65 is offline   Reply With Quote
Old 04-28-2006, 01:42 PM   #14
arcblue
Lynnwood, WA
'92 XLT
Vehicle Specs
Quoted: 0 Post(s)
Glacier991, thank you for the detailed description with pictures. I just did mine last night. I was going to tackle it myself this weekend but got the help of a mechanic friend. A couple of other issues with this job: The new core's input/output tubes needed to be "adjusted" a bit so they were the right distance apart to fit thru the holes in the firewall, and we had to come up with some weatherstripping to put around the new core (the old one used foam tape, which we couldn't reuse on the new core). Also, be prepared for coolant to come gushing out for a few seconds when you remove those hoses. We also replaced the old-style hose clamps with a newer design. So nice to have this fixed so I can turn on the blower again and smell nice clean air.
arcblue is offline   Reply With Quote
Old 08-10-2006, 06:29 PM   #15
biggs92EB
Biggs, CA
biggs92EB's Avatar
92 Special Eddie
Vehicle Specs
Quoted: 0 Post(s)
just did my heater core yesterday, it was easy. i did have debri in the box though, my question is, is it completely necessary to have the weatherstripping around the new heater core? i put it back together without it, and im not sure if its gonna rattle around and break in there, i do ALOT of wheelin so...also i had to cut a piece of hose off so now i dont have enough hose for the one that goes to the water pump. i cannot for the life of me get to the clamp on the waterpump side, do i have to take out the fan? or is there a trick that i dont know..thanks james
__________________
92 Eddie Bauer
biggs92EB is offline   Reply With Quote
Old 11-30-2006, 02:59 PM   #16
bikerchick4God
N Charleston SC
'94 XLT
Vehicle Specs
Quoted: 0 Post(s)
MANY THANKS for the instruction. was quoted $400 for a 4 hr job to replace this! dang!!!! I was gonna cap off the lines but have decided to replace the core as advance auto has it for $21.88 in daytona beach!
__________________
it's not the heat, it's the humidity...
bikerchick4God is offline   Reply With Quote
Old 12-07-2006, 07:33 PM   #17
bikerchick4God
N Charleston SC
'94 XLT
Vehicle Specs
Quoted: 0 Post(s)
Some basic information is overlooked for newbies like me. Hope this helps someone else not waste hours trying to figure this stuff out.
I didn't know how to remove the plastic rivets that hold the carpet in place under the dash! Finally found out: Grab the head with a pair of pliars, I used locking pliars, and pull hard. They pop right out. Pkg of new ones can be had from auto parts stores for around $3.
Before replacing the heater core I flushed the radiator and cleaned the overflow container with a toilet bowl brush! I didn't know how to remove the wiring connector for the washer fluid pump. Called Ford: Use a screw driver to push each small, side clamp away from the connector and you'll see how it moves away to release the connector from the container body.
Thanks. Forgive my language if it is not correct.
__________________
Old 10-30-2007, 04:17 AM   #18
gblues
Caldwell, ID
93 Explorer
Vehicle Specs
Quoted: 0 Post(s)
I just did my core; this is my first experience with any sort of automotive work since high school shop class, so I'm very much out of my element. Here's my story:
Got a new core at Napa for about $25 + tax. Got the clamshell open without any issues. The hoses were another issue.
I loosened the clamps on the hoses, and the right-hand hose came off without too much complaint. The left hand hose, however, was stuck. I ended up having to... improvise.
By "improvise," I mean cutting the hose off. I did the initial cut with an old beat up saw but the saw was more suited for metal and I didn't have a good angle. Plus, it was a crap blade. I ended up finishing the job with a steak knife!
After getting the hose off, I still couldn't get the old heater core out because the bit of hose on the core simply would not come off. So, improvising again, I cut the stuck hose with the steak knife lengthwise.
At last, I got the old core pulled and the new core installed.
My next problem was reconnecting the hoses. The right-hand hose was a cinch, since it came off the old core without a protest. But I had a new problem: my amputation left the left-hand hose too short to reconnect! With dismay, I follow the hose to the other end; replacing the entire hose was out of the question for my time and financial budget. My wife had the smart idea of using a hose splicer (which I'd need anyway to join the two hoses if my core replacement went completely TU). Back to Napa!
I ran the problem past the counter guys at Napa, who suggested cutting off a few more inches of hose, then using the splicer to join the main hose and the new fragment to the core. One splicer and 2 hose clamps later ($4 and change) and I'm back to work.
The rest is pretty smooth sailing from there. I start by cutting my segment of hose (again, w/ the steak knife) and clamping it onto the core; I attached the splicer and clamped it down, and after everything was secure I fired up the engine.. and to my delight, antifreeze did not go spraying everywhere! I added a little antifreeze to replace what leaked during the core replacement.
I haven't had a chance to test to see if the heater actually blows hot now, but looking at the old core I can't imagine it was working. Still, can't beat just over $30 vs. the $200-300 quoted by the mechanic.
Nathan
gblues is offline   Reply With Quote
Old 02-18-2008, 03:17 AM   #19
73Elsinore
Central California
'91 XLT 4x4
Vehicle Specs
Quoted: 0 Post(s)
Just to add to this...
- If you haven't replaced your heater hoses recently, this is a good time to do it. That way you can just cut the old hoses off the heater core tube connections and you don't have to wrassle them suckers off.
- When you have the old core out, make sure the drain hole from the heater plenum going to the outside is not plugged up. They somehow do plug up with road debris. Mine was. This is the drain hole shown in one of the photos. If it's plugged, and the core fails, you get coolant all over the inside of the passenger footwell.
- I had a brand new Ford heater core fail right out of the box. Installed it, drove the truck a few miles, and had coolant all over the ground, coming out of the heater plenum drain hole. Nice.
- None of the aftermarket heater cores I got would fit in the plenum correctly. I couldn't stuff enough rubber in there to make up for the air leaks and the crummy fit. The Ford core was a perfect fit.
__________________
Thanks! Pete
Engineer's Law - pick any two:
Good Fast Cheap
73Elsinore is offline   Reply With Quote
Old 03-07-2008, 02:25 PM   #20
Draegonsan
Omaha Nebraska
Draegonsan's Avatar
'94 xlt (not 100% sure)
Vehicle Specs
Quoted: 0 Post(s)
I just wanna say thanks a ton..I posted a thread asking for help on this and withing minutes was directed here to the article...great directions very short and simple... i thought I was going to have to remove the dash..hence my last 2 monthst of suffering in the cold here in nebraska. Now I know and this is getting done tonight. lol thanks a lot ill update ya'll on how I do.
__________________
Fadein2madness gamertag xboxlive
http://www.myspace.com/thedraegon
K. Bryson. acts 4:12
'94 explorer blue
'07 G6 GT red
'03 Suzuki sv650s metal orange
Draegonsan is offline   Reply With Quote
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
1st Gen Steering Wheel Replacement Jerameya Modified 1991-1994 Explorers 6 07-01-2014 10:38 PM
Problems with tempeture after heater core replacement Jimi_73 Stock 1995 - 2001 Explorers 2 10-02-2012 12:45 PM
Heater Core Flush, 2001 Explorer 4.0 Pretzel60 Stock 1995 - 2001 Explorers 18 02-03-2012 01:58 PM
95 Explorer wont start after heater core change scotts1964 Stock 1995 - 2001 Explorers 0 11-28-2008 01:38 PM
1991-1994 Heater Core Replacement Diary Glacier991 Explorer, Ranger, A/C & Heater systems HVAC 1 05-03-2006 02:16 AM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Copyright 2016 - 1996 Rick Horwitz Photography Explorer Forum is celebrating it's 20th birthday!!
Ford Motor Company is not involved in the management of this site in any way.
