Ford Explorer Sport Trac Ford Ranger Mazda Navajo Mercury Mountaineer, Ford Aerostar Message Board®
Ford Explorer, Sport Trac, Mercury Mountaineer, Mazda Navajo, Ford Ranger, Ford Aerostar SUV Enthusiast Forums
Join the "Elite Explorers Today!"
Explorer4x4 Sportrucks 2011 Explorer Forums Elite Membership Product Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac.
Reply
Thread Tools
Old 07-28-2006, 06:27 AM   #1
dkoets
the netherlands
'98 xlt
Vehicle Specs
Red Exp Radio / Clock display problem 1998 and up Explorers ( blank / fade / blanks / fades )
Finally the answers after days of searching:
Quote:
I had the
same problem in my 98 Explorer. The problem is with the display power
supply board getting too hot and cracking the poorly solder joints.
You have two options if it's not under warranty. One, you can try to
re-solder the joints. Two, you can replace the board. I tried to
re-solder the board with no luck. I had to replace the board. I will
include information at the bottom of this posting on where to buy the
board. It took me a long time to find someone who sold the parts.
Here are the instructions to re-solder the board. They were posted in
a Ford radio news group.
To try to re-solder the board....
MAKE SURE YOU HAVE A LOW WATT SOLDERING IRON AND SMALL SOLDER.
Here's the directions that helped me...Good Luck:
By opening up the radio you will find a narrow display power board
With in the left side of the radio (faceplate toward you). This board
has a metal cover soldered to it, with a toroid (wire wound doughnut)
inside on one side, and a bank of surface mount resistors and
capacitors
on the bottom side. One end of the board (SCR heat sink) is screwed
to
the heat sink at the back of the radio, the board is secured with 2
metal bend-tabs, and it has a white mini connector on the other end
which connects to the faceplate. Remove the board from the radio.
On the bottom of the board look for surface mount components
R1057/C1071/R1058/C1083/R1064. The colder these resistor/capacitor
chipsets get, the brighter the display. I left the car out in the +5f
degree weather and the display worked until it warmed up a little.
That
is how I was able to track it down to these temperature sensitive
parts. Freeze-it also helped after I narrowed it down to a few
components.
Here is the contact information for vendors who sell the replacement
board.
2
I have traveled this road. I have a 1998 Ford Explorer with a blank
radio display cd\cassette\am\fm. I tried to re-solder the components
on the display power supply as suggested on previous posting with no
luck. I looked on ebay but didn't see anything worth buying. I again
tried to re-solder the board...still no luck. So this is what I have
learned. If you can't fix it with the re-solder posting, or don't
want to try it, you will need to replace the display power supply.
Most radio shops I called said they only do component level repairs
starting at $100.00. Then I found a few shops that have the circuit
boards for sell. The board comes in a 3 board set, a new power
supply
board and two new tuner type boards, sold as a "compound set". Here
are the shops I found that have it.
Speed-O-Tach, Inc. they sell the 3 boards for 73.95 + shipping (5.00
ish)
Auto Radio & Electronics PART NUMBER HWM0043
Corporate Office
4090 Pike Lane
Concord, CA 94520-1227
Toll Free: 1-800-442-4491
Tel: 925-691-4090
Fax: 925-691-4101
or
speedometerservice.com 3 boards cost is 82.82 6.75 shipping
Phone number
1-800-332-1827 Georgia Watts
1-800-241-2385 National Watts
I found other sites but the price jumped to 215.00!
The board is very easy to swap. Pull the radio out, take to 2 black
screws off the side of the face plate (1 on each side. Face the back
of the radio, now remove the screw in the top right corner. Pop the
front and top cover off the radio. Unplug the blue cable that leads
from the display to the display power supply. There are 2 tabs that
hold the power supply in. One is next to where the blue cable plugs
into the power supply. To find the other tab, look inside the half
circle on the tin heat shield. The board is painted white where the
tabs are. Now straighten the tabs with a screw driver. Pull straight
up on the tin heat shield. Now you have it out swap it with the new
one and put it all back together.
3 (*** this helped me ***)
I have a '00 that just developed the blank display syndrome. From all these good inputs, locating the display power supply (the small board mounted to the left side of the CD chassis and connected to the display by a small cable consisting of blue insulated wires) was not much of a problem. Examination of this board from the bottom side showed some heating and with a 5X jewelers loop a person could see broken solder joints. Soldering these joints, especially those associated with the surface mounted components took very a sharp soldering iron (taking a standard Radio Shack type, 25W and sharpening the point so that taper starts about 3/8" to 1/2" from the tip worked very well). After re-flowing, and adding solder in some cases the display works as new.
Now then for the fix: Obviously the display power supply is running at a high enough temperature to damage the solder joints but not so high as to damage the components. Solder will remain structurally sound to about 230 degrees F. any substantial increased temperature will weeken the joints allowing the mass of the component, thermal expansions and contractions and residual stress from the original soldering event to tear the joint apart. Or in other words the newly soldered board will fail in a month, 6 months, or maybe if your lucky several years if steps are not taken to cool the board. At www.pricewatch.com several vendors advertise fans as small as 1" square. With file a 1" square fan will fit at an angle from back to front over the front of the power supply board. Using a little 5 minute epoxy the fan can be secured to the chassis and connecting the fan power between the ignition on power (at the radio connector) and ground (the chassis) will cause the fan to run any time the ignition is turned on. The drawback to this fan is, it can be heard when the ignition on and the engine not running.
dkoets is offline   Reply With Quote
Sponsored Links (Less Ads)
Old 08-09-2006, 03:40 PM   #2
Rick
Admin
Pumpkin Pilot
Wayoutin, Aridzona
Rick's Avatar
'93 XL
Vehicle Specs
Thanks for compiling the info. I set you up with 3 months of Elite Explorer benefits.
__________________
Rick Horwitz, AB7FH "Serious Exploration's" Admin
Rick's '93/'98 Explorer
Dodge Dart 512 Resto/Race
2004 Mustang Mach 1
2003 Dodge Ram/Cummins Dually
Rick is offline   Reply With Quote
Old 09-05-2006, 12:29 PM   #3
mikeh
St. Louis, MO
98 XLT SOHC V6
Vehicle Specs
Actually I would use Trevor at Pacific Audio http://home.comcast.net/~pacificaudiotech/
He fixed mine quick and for $50 a while back.
That was the smartest way I can think to fix this problem.
mikeh
__________________
Mike H
mikeh is offline   Reply With Quote
Old 09-12-2006, 06:48 AM   #4
gijoecam
Village Idiot
Trenton, MI
98 ExSport, '00 F-150
Vehicle Specs
I'll second the vote for Trevor. I tried to fix mine per those instructions and only succeeded in making mincemeat of my board. Trevor took care of it for $70 including return shipping. (Given the amount of damage I did to the board, it should have been a $90 repair easily!) He also checks, adjusts, and lubes the CD and Cassette mechanisms to ensure they work well. All is well almost a year later!
-Joe
__________________
-98 Explorer Sport, 4.0 SOHC, K&N drop-in, LEMON in progress!
-'00 F-150, mucho mods, Photo gallery Here
"We need to allow Darwinism take it's course and let the idiots weed themselves out of existance." ~ Rick Horwitz
We must believe in free will — we have no choice.
~ Isaac Bashevis Singer
I'm not smart, just a resourceful idiot. ~ Me
gijoecam is offline   Reply With Quote
Old 11-11-2006, 12:36 AM   #5
Jetvol1
Knoxville,TN
99 xlt
Vehicle Specs
That
components.
There's the key. Combined with info from the pic's you'll see a 2w resistor mounted to the opposite side of the board of the surface mount components
Each leg of the resistor had about 1/4 inch (ok maybe less) sticking out of the board on the bottom. I'm imagining that the 2w resistor got too hot and heated those components up.
I'm hoping the quick fix of push those legs in (therefore moving the resistor away from the board) with the soldering iron is the key.
Mine is working now but we'll see what happens in the next few days.
Thanks for all the info guys. Very cool.
Jetvol1 is offline   Reply With Quote
Old 11-11-2006, 09:03 AM   #6
raleigho
Houston Texas
98 Eddie Bauer 2wd
Vehicle Specs
dkoets,
I, like you, did the repair numerous times, only to have it fail after a couple of weeks. I used your recommendations, and order a new board from Speedometer Service, replaced the board and I'm done with the problem. I checked prices, and they were competitive, and very prompt in delivery.
Thank You for your help, and advice.
raleigho is offline   Reply With Quote
Old 11-14-2006, 04:03 PM   #7
gijoecam
Village Idiot
Trenton, MI
Vehicle Specs
Just an update: Mine was repaired by Trevor at PacificAudioTech.com now almost a year ago. I'm happy to report the problem has not yet returned.
-Joe
__________________
Old 11-29-2006, 05:47 PM   #8
rtbrjason
Rochester, NY
98 5.0 EB AWD
Vehicle Specs
I went through this as well with the mach stereo in my 98. I tried soldering and had no luck. I purchased the board installed it and the display has worked since.
What I've noticed though, is that the button illumination on the stereo is intermittent. Most of the time the buttons will no light up, or are very dim. Sometimes they are fully lit and look great.
Anyone else having this issue or know which solder joints to check? I'm about to pull it back out and retouch up any weird looking/burnt joints.
rtbrjason is offline   Reply With Quote
Old 11-29-2006, 06:39 PM   #9
Jetvol1
Knoxville,TN
99 xlt
Vehicle Specs
Well guys after a week mine stopped working again. Still working on it.
Old 12-16-2006, 05:29 AM   #10
2000LTD
Iowa City, IA
2000 LTD AWD
Vehicle Specs
I'm thinking I'm gonna send mine to this Trevor fella. Accounting for shipping time, about how long should I expect to be sans-radio and staring at an unsightly hole in my dash?
2000LTD is offline   Reply With Quote
Old 12-16-2006, 08:24 AM   #11
gijoecam
Village Idiot
Trenton, MI
Vehicle Specs
Mine took him four days to turn it around, but that was my fault as I had attempted the repair myself and made mincemeat of the board in the process. Ordinarily his turnaround is a couple hours from the time he starts on it, and it ships out the next day.
You'll be quite happy with the service. Mine's still working.
-Joe
__________________
Old 12-30-2006, 12:00 AM   #12
mggustaf
La Center, WA
99 XLT
Vehicle Specs
I sent my Mach unit to Trevor at Pacific Audio (http://home.comcast.net/~pioneer_dualmedia/index.html) and I had the unit back in 4 days. When I first contacted him (I wasn't going to send a several hundred dollar head-unit to a faceless web site) he asked if I had already tried to fix the unit myself. He was upfront about telling me he charges an additional $15 for my "help." I have had the unit back for over 6 months now and it works like new. I highly recommend his services.
Marty
mggustaf is offline   Reply With Quote
Old 12-31-2006, 11:20 AM   #13
MustangAndy
I'm Elite,Why Aren't You?
J-Town, NJ
MustangAndy's Avatar
2003 F-150 4x4- NO X HERE
Vehicle Specs
Smile '98 Radio problem: How I fixed it
I had the same problem (Like most everybody). Come to think of it I had a friend with a '98 XLT with the same. Screen would work for a short while then blank out. Also for me different lights for different functions would go out. I.E. the #5 button would light for the AM/FM but go out when switched to CD mode.
For me I pulled the radio and had my dad look at it. He resoldered everything and that brought back some of the lights and the screen would work for awhile longer.
I eventualy got quite annoyed at this and decided to simply swap out the radio from the one in my Mustang. Stang was upgraded to a Pioneer DEH-6700MP in '05 as a H.S. graduation present.
To do this I had to get a bit creative:
Working with a '98 Explorer Sport and a '02 Stang V6 here. The radio from the Stang is a Premium style with the AM/FM/Cass/CD option. No Mach:
1) I started by taking out the Explorer's radio (AM/FM/Cass/CD) by using a pair of "Radio removal tools" I picked up at Pep Boys for $6 (Look like "U"s), and tossing it in the back seat. There is a trick to these radios. The object of the game is to put the tools in till they clip then pull them sideways to the outside of the radio . After they are at an angle you then pull foward. Keep them straight and they just pop out without the radio.
2) I then removed the (2) 9/32" Hex head screws on the bottom of the console piece and took it out. (There's probly a Metric size that fits better, but seeing as 9mm was the smallest metric I had, SAE won. 1/4" is too small BTW)
3) Using a plastic cutting tool I trimmed away the lip on the console where the Explorer's radio would have stopped. This lip acted like a stop to keep the radio from being shoved too far in.
4) Seeing as the radio from the Stang was bolted into the console and not hooked like the Explorer, I had to remove the small metal trim plate from it. It was held on with 4 tiny Torx screws.
5) I then hooked up the wires to the back of the Stang's radio (Idiot Proof).
6) I put the radio in FIRST then put the console piece back on and reinstalled the 2 screws on the bottom.
Done. Stang radio works fine and looks like factory. Best part is that I have the radio controls in the back console and they interface with the Stang radio just fine.
__________________
EXPLORER WAS REPLACED WITH AN F-150 - BUY MY STUFF- I DON'T NEED IT:
RANDOM STUFF: http://www.explorerforum.com/forums/...d.php?t=220959
23YO with 4 cars - 1985 F-250 4x4 6.9L diesel, 2003 F-150 4x4 5.4L V8, 2002 Mustang 3.8L V6 -PROJECT-, 1970 Mustang Grande' 302 V8 -FOR SALE-
MustangAndy is offline   Reply With Quote
Old 01-06-2007, 09:20 AM   #14
mswann
Columbia, Missouri
1998 Explorer Eddie Bauer
Vehicle Specs
Thumbs up It works!
I guess the third time is the charm. I was excited to see the thread on the blank radio fix, since mine has been out for 2-3 years. Interestingly, on the coldest day of the year (under zero) my radio lights would work for about 10 seconds every year ... I thought it was a teaser from satan himself until I read the thread.
I'm no electrician and not a mechanic by any means, but since I recently swapped out my heater core because I was down on cash, I had some extra confidence that the instructions for this would be worth a shot. I spent about $20 at radio shack on an iron and solder, then pulled the radio with a bent clothes hangar as described. The first two times, I only soldered the joints that "looked bad" and it didn't work either time. I nearly gave up, but then I heated every joint on the board and it has been working, bright as ever, for the past 2 months. Thank you explorer forum and to all of you who have worked this out. My first post here, but I'm a big fan of the site!
Now I had a fender bender the other night and tore my front valance on my 98 eddie bauer and need a tan replacement ... i'm having trouble finding one at a salvage yard ... anyone have ideas? Thanks.
mswann is offline   Reply With Quote
Old 01-07-2007, 08:35 PM   #15
Donut
Norman Oklahoma
2001 merc
Vehicle Specs
blank display
Hey Guys
i took the front cover off my radio like the post said. i look at all the joints. the ones coming out of the display were intact but had some browning on the board . on the display but the clock there was a discolored spot on the crystal. so i think its failed internally. if anybody has pics of before and after i'd like to see them so i have a better idea
thanks Matt
ow yeah two penny's fell out off radio when i took the cover off im sure that didn't help the problem
Donut is offline   Reply With Quote
Old 02-08-2007, 03:56 PM   #16
viper1314
weston,wv
98 sport
Vehicle Specs
That
components.
has anyone just tried replacing the resistors? I imagine replacing every part on the board would still be cheaper then the new board for 75+
Mine came on today again for about 2 minutes (it was about 7* out) I went to set the clock and she went blank again as I was about to set the minutes
viper1314 is offline   Reply With Quote
Old 02-14-2007, 10:25 PM   #17
scucci
98 Sport
Vehicle Specs
The first repair I made the day after I bought my 98 was the radio display. Since I have been an electronics tech and taught high reliability soldering it was not a tough job. The resistor dissapates a lot of heat and has a small solder pad and substrate for heat transfer. This magnifies any soldering defects. You really need to work under a magnifier. The solder joints on this board are not very high quality. The ones I have seen all had contamination and were not soldered at the correct temperature (cold joint). You need to clean the board first. I used radio shack flux remover. Next I removed the old solder and cleaned the resistor leads and pcb pads with a pencil eraser. Then placed a drop of liquid rosen flux on the leads and pads. I used silver bearing solder available at radio shack. This or eutectic 63/37 solder work the best. The eutectic solder has a narrow plastic temp range and so it is easier to prevent movement of the component leads. Movement of the leads while the solder is molten and cooling to the solidification point causes a frosted looking weak joint. Then I removed the solder from all components and cleaned, fluxed, and soldered them. That was 2 years ago and it has not failed yet. The problem is poor design practice and poor quality control. There is an old saying in solder land "the bigger the blob the better the job". This is meant as sarcasm by qualified techs. There should be just enough solder on the joint to form a well defined fillet.
A 12 volt 25mm square ball bearing muffin fan can be used as the previous post explained . I just searched and found one here.
http://www.hardwarecooling.com/produ...5x25x10mm_Fan?
You get what you pay for. The sleeve bearing fan will make a lot of noise and fail quickly. I have seen theese fans cost up to $60 for the best high end. I did not not put one in my radio. If the board fails again I will purchase the newer redesigned board. Hope this helps in somebody in some tiny way.
Scucci
scucci is offline   Reply With Quote
Old 02-14-2007, 11:07 PM   #18
viper1314
weston,wv
98 sport
Vehicle Specs
thanks for that post man, I will re do mine when I get a chance, hopefully this weekend or the next.
I was in Electronics Engineering Technology for 1.5 years and worked a summer in the field (thats when I realized I dind't want to do that haha) so I should be able to take care of this.
Old 02-16-2007, 06:41 PM   #19
Toucan
BELIZE
1998 XLT
Vehicle Specs
I did my own repair when I bought my '98 3 1/2 years ago. It worked perfect up until about 2 months ago. I went back in and cleaned up a re-soldered. BUT forgot to replace the large metal cover in testing it. The face of the radio shorted out and broke one of those thin thread like things. Radio "sound" is perfect but no more display!!!! Need to replace at least the face. ( I did try to repair that but to no avail.) Will have to wait until one reaches a junk yard. In our country these radios are not common. Mein it sucks!!
Toucan is offline   Reply With Quote
Old 03-11-2007, 01:18 PM   #20
KLW
Peabody, Kansas
2000 AWD 5.0
Vehicle Specs
Toucan, I did the same thing to my radio! I had the circuit board loose trying to figure out what solder joint I missed and all of a sudden smoke rolled from my unit. I found out I had smoked one of the circuits on the front panel. I repaired it with piece of "braid" from the solder remover I had but still no front panel lights. I purchased another radio on ebay last night that is guaranteed for 15days (woopdedoo). I'm not sure my smoking the front panel is my problem now or I just need another power supply board. Hopefully the new radio will work a long time. I did get my lights to come on for a half an hr or so after my first solder job when I hit the top of the radio. Everything else works ok. The Radio Shop in a nearby town said an exchange radio was like $399 with a 90 day warranty. They're going to look at my subwoofer amp since it doesn't work. They wanted $169 for a exchange on the amp. My cost from Ford for the whole subwoofer was $199 which I'm assuming includes the amp.
KLW is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
Copyright 2010 - 1996 Rick Horwitz Photography
Modifying the suspension on any vehicle will cause changes to it's handling characteristics.
