HHO: Is it alchemy? Or will it improve gas mileage on a ’99 4.0 SOHC Explorer? | Page 24 | Ford Explorer Forums
In Town Gas MIleage
I was blown away when I refilled the tank. I had used only 1/4 of a tank and the odometer clocked 245 miles.
It took 7.2 gallons of BP 89 fuel netting 34.02 MPG.
well now that is interesting :thumbsup: and enough reason for me to start doing some playing myself.
OK I'm game, Josh send me those plans along with that document, the more I read the better my system will work, well in theory anyway.. Btw for all the fuss you made over cutting the plexi, your stuff looks really good, what did you use to glue it together? or did you weld it with a plastic welder?
keep those numbers coming, before I can play around with the hho I need to get my UD pulley on. I finally got around to putting in my electric fan tonight, but I didn't have time to drive it much, since it was a perfect night for fishing :D
I want to have a few weeks of driving with these mods so i have a good baseline to compare it to.
anyway, I am ready to build some of these, maybe see if I can get my wifes car into the high 40's or 50's
That is unreal Al! Great to hear. I may have to jump on the HHO bandwagon soon.
That is great. Do we know yet how much the MAF adjuster has helped separate from the HHO system?
No. It is used as a component of the HHO "system", I have no intention of using it without the HHO generator.
WOW! that is amazing. I still need to put that MAF adjuster on my V-8 Mounty and see what I can get. So far with only the single HHO I am getting about 16.8 MPG in town driving. I do not use this truck daily so I amnot rushing.Going to try to figure out the MAF today if I can figure out which wire to connect to.
It should be determined how it affects and the results it produces on the engine by itself. Because it is leaning the fuel mixture.
MAP / MAF Sensor Enhancers for $54.95
I am offering Dual Edge MAP / MAF Sensor Enhancers for $54.95 and free shipping in U.S..
See more at www.HHOEnhancers.com
they shipped my HHO kit today, should see it within a week, aldive are you using the baking soda for the additive?
thanks
i think i will test with and without the maf/map sensor enhancement
josh is the man
josh, wow what a read, a little long only 156 pages with pictures, jumpy at time but really good read over all.
:us:
does any one know a good and cheap (I know they don't go hand and hand but) obII scanner so I can monitor my truck vitals with these projects coming up!!
other notes I am getting my red top optima today electric fans and hho gen project wil start in a couple weeks!
tom
:us:
tom
Relatively cheap is the ScanGaugeII, about $160. I have one, and several other members do too, seems to be pretty accurate as far as sensor readings from the engine.
