Transmission help!!! Plez!!!! | Ford Explorer Forums
blackbelt980
Stone Ridge, NY
1995 Ranger
Ok. I have a 1995 ranger 2.3l automatic with a 4r44e transmission,and ive been havein transmission problems for about a month now. It first started with the o/d light flashing and then it progressed to loss of o/d. I replaced the ABS and the turbine speed sensor. Still problems. I also flushed and replaced the fluid and filter. I read on the forum that tightening the bands might help. I just finished that today and I have overdrive now. But the o/d light is still flashing and it goes into limp mode like it did before. So please i need help. please im all out of ideas. I need to fix it as soon as possible..
...You need to have your codes checked as it may give us a better idea as where to start...
...Did you just start replacing stuff or did you have a code first that you worked from???
Um at first I would randomly have a code for the turbine sensor. But then I replaced it. And ever since then i havent had any codes. But still the flashing o/d light, and the "limp mode"
Like i said in the other one. There is no code coming up. I check it daily and nothing changes. That is why i am out of ideas .
