laneo9417
- June 12, 2012
- MA
- '98 XLT
So I was cruising down the highway last night when the check engine light came on. I pulled into Autozone and borrowed their OBD tool and got the P0442 code. I’m thinking (and hoping) that this is just a gas cap/filler neck issue because the truck is idling fine with no noticeable changes in the ride. The gas cap is the original but the rubber seal looks fine (there are no cracks and it's not warped or anything) and it clicks and locks into place normally. The filler neck is also the original but it does have a decent amount of rust, including around the outside of the neck where the cap locks in. I’ve done a fair share of research on this topic this morning but I still have a couple questions because I have seen conflicting answers:
Can the code be cleared without an OBD tool, such as disconnecting the battery? I would like to try this first to see if I can get the check engine light to stay off (hoping it was just a loose gas cap that triggered the code).
If the check engine light stays on (or comes back on) would it be fair to say that a small crack or hole in the filler neck is to blame given the truck is running completely normal? I’ve seen filler necks for sale on 1Aauto and Rockauto fairly cheap, and they seem relatively easy to replace.
Any help is appreciated.
