Bob71
- August 22, 2011
- New Orleans, LA
- 2011 Explorer Limited
I have a 2011 Explorer limited with 23500 miles about 2 weeks ago it started with a wrench light coming on over the tach. When it comes on you loose all throttle (no gas pedal at all NOTHING) when you hit OK for the wrench the tach comes back on and it is tach at 1000 rpm you give it the gas nothing. It will continue to roll until you put your foot on the break to stop it and if you release the break it will start rolling again. If you put it in neutral still no throttle control and still tacking at 1000 rpm. Shut it off and restart everything go back to normal. This has happen 3 day in a row, brought it to dealer they had it 1 week drove it 300 miles and it did not occur again. (Can't see can't fix) But the third time it happened I took a video which they have a copy of. But even with the video they still can't fix it because the COMPUTER did not give a code for turning the WRENCH ON.
I told the dealer that at Ford someone knows why the light came on. something turned the light on and disconnected the throttle code or no code.
After I got it back it happened again with my wife an now she has a video of it and I have told Dealer that I have it on video again. We are now weighting to see what the service manager is going to do next.
Has anyone else had a problem like this? I could not find anything on the site.
