beach
- May 15, 2006
- south florida
- Coyote F150
Just saw this section. On a 00' 5.0, how do you remove the radiator from the condenser? I have all hoses off, all bolts out, shroud off, as well as the lines removed like for the trans etc. Unscrewed the bottom bolt that holds/guides the two lines below the radiator. Only thing that should be holding it in is the clip on the bottom passenger side. But in the manuals and online I keep seeing remove the "clips", but I only see one clip, not "clips"?
Am I doing this right, I have that clip compressed and pulling, or trying to, the radiator forward to unhook off it to pull it out....but I'm yanking like hell and its not budging.
