#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Explorer & Ranger Transmissions, Transfer Cases, & Differentials
Notices
Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35
4R55E band adjustment.
Reply
Thread Tools
Old 03-21-2004, 01:35 PM   #1
DazedNConfuzed
Orlando, Fl
1996 Explorer XLT 4D
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
The 4R55E has a single or double wrapped band? I'm going to install a transgo shift kit in my 96 X, and have no idea if i should back the stud out out 2 or 3 turns for overdrive band. Help would be appreciated.
Thanks
__________________
1996 Ford Explorer XLT in the works
2002 F150
DazedNConfuzed is offline   Reply With Quote
( Join the Elite Explorers )
Old 03-21-2004, 02:36 PM   #2
Glacier991
EF Tranny Guru
Sacramento, CA 95827
1992 XLT
Vehicle Specs
Quoted: 4 Post(s)
the 4R55 is a single wrap (as I believe everything 92 and later was). 2 turns.
Glacier991 is offline   Reply With Quote
Old 03-21-2004, 03:48 PM   #3
DazedNConfuzed
Orlando, Fl
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Also what are some signs that the bands in this transmission are out of adjustment. For some reason this truck doesn't seem to have the acceleration it used to, and the motor seems to rev higher to get to the same speed. Like a clutch going bad, not getting all the power to the ground.
Thanks
__________________
2002 F150
Old 03-21-2004, 04:36 PM   #4
Glacier991
EF Tranny Guru
1992 XLT
Vehicle Specs
Quoted: 4 Post(s)
You didn't say the mileage on this trannie. Your concerns could be caused by a lot of things. Would't hurt to adjust the intermediate (most rearward) band. Buy a new nut. A reasonably painless procedure, and if that's not the problem, nothing lost but the price of a new nut (and a 1/4 in torque wrench if you don't have one. If it high mileage, odds are that is not it, but rather it maybe a combination of factors, all age related.)
Old 03-21-2004, 05:03 PM   #5
DazedNConfuzed
Orlando, Fl
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
96 Explorer, 40,000 origional miles. Was my mothers car, sat in storage for a while, but run once a month. I blew the rear end up in my F150 offroad, so i started driving this. Changed all the fluids before i drove back to college. And what are the exact adjustments for the bands anyway.
Thanks Dude
Dazed
__________________
2002 F150
Old 03-21-2004, 08:29 PM   #6
DazedNConfuzed
Orlando, Fl
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Anybody?
__________________
2002 F150
Old 03-22-2004, 03:02 AM   #7
Glacier991
EF Tranny Guru
1992 XLT
Vehicle Specs
Quoted: 4 Post(s)
Intermediate band:
Remove and replace the locknut. Tighten the adjusting screw to 10 foot pounds .... back it off 2 turns, hold it stationary and tighten the locknut. Done.
Old 03-22-2004, 10:47 AM   #8
Opera House
Cincinnati, OH
97 Explorer XLT
Vehicle Specs
Quoted: 1 Post(s)
The nut has an O ring under it that will be welded to the adjustment screw by this time. That may cause you to back out the the adjustment screw at the same time. I wouldn't back out the screw any more than 5 turns or thins will fall out inside. You will need to cut off the old O ring with a box knife in order to tighten it in prior to adjustment. A new O ring that will eventually press into a groove on the nut can be slipped on later. Personally I think it is a bad idea if this only has 40K.
__________________
Rule #7: Believing and seeing are often both wrong. (FOW)
02, 97, 92 Explorer XLT 4X4 4.0L
Opera House is offline   Reply With Quote
Old 03-22-2004, 10:58 AM   #9
Glacier991
EF Tranny Guru
1992 XLT
Vehicle Specs
Quoted: 4 Post(s)
Good point Opera House.
Old 02-08-2012, 10:26 AM   #10
4.0exploder4j
Hollister, mo
4.0exploder4j's Avatar
1995 ford explorer xlt
Vehicle Specs
Quoted: 0 Post(s)
1995 ford.explorer band question
When I adjust the bands on my transmission in the truck do i make a complete circle or do i turn about a quarter for.a turn cause it seems alittle tight to make a complete circle to were I started turning please first time doing this
4.0exploder4j is offline   Reply With Quote
Old 02-08-2012, 10:34 AM   #11
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 380 Post(s)
Two turns are complete turns. Check the band adjustment sticky thread on the top of the transmission section for more information.
BrooklynBay is offline   Reply With Quote
Old 02-08-2012, 11:44 AM   #12
4.0exploder4j
Hollister, mo
Vehicle Specs
Quoted: 0 Post(s)
so go completely around to where you started
So i go completely around to where I started turning is that right
Old 02-08-2012, 11:11 PM   #13
drdoom
VA
2005 Eddie Bauer 4.6L 4X4
Vehicle Specs
Quoted: 306 Post(s)
Are you using a torque wrench?
drdoom is online now   Reply With Quote
Old 02-10-2012, 07:55 PM   #14
4.0exploder4j
Hollister, mo
Vehicle Specs
Quoted: 0 Post(s)
Yes I am using a torque wrench
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
a4ld rebuild - 4r44e vs. 4r55e lonestar Under the Hood 4 09-21-2012 04:42 PM
4r55e with slipping 3rd gear Gatornga Explorer & Ranger Transmissions, Transfer Cases, & Differentials 5 08-22-2010 09:48 AM
shifting problem after 4r55e rebuild< could it be the servo? kindred4x Explorer & Ranger Transmissions, Transfer Cases, & Differentials 6 04-20-2010 11:19 PM
New Ranger. Lift idea help. C_7777 Ford Ranger - Mazda B-Series Forum 33 12-16-2008 09:32 PM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
