- November 11, 2005
- Brooklyn, NY
- 88 89 93 95 96 Aerostars
Take a look at the yellow page section of WWW.Superpages.Com for a local transmission parts store.
If the band adjustment didn't help, then it could have other issues such as an out of spec modulator or kickdown cable, clogged valve body or filter, leaking servo pistons, worn clutch pack plates, etc.
The solenoid block might have failed. Do you have over 60K miles on it?
You could verify this by checking the pressure with a 0 - 300 PSI test gauge.
Don't reuse the old torque converter. Use a remanufactured torque converter, and flush the cooling lines. Rebuild the old transmission since it's out of the vehicle.
