gwiysel
- June 7, 2004
- Minneapolis
- 94 XLT
This forum is absolutely the best for us inquiring minds and i'm happy to have it available. My 94 x just died at intersection and sounded like it was robbed of fuel prior to dying. Fuel pump whines for couple seconds every time key is first turned on, just cranks but will not even try to start, there is no fuel (or pressure) released when depressing the little valve on the fuel rail. Just replaced pump and filter last year and regulator last month. Been there, done that, got the tee-shirt for the relay problems that seem to be a common issue w/x. It ran like a champ before stranding me at a major intersection. There are no codes set and resetting the computer has no effect. After cranking the engine many times, I remove the fuel cap and I hear not even the slightest pressure released.
Questions for the mechanical GOD:
If the pump was defective, would you hear the 2sec whine? I've heard that the (CPS) crank post. sensor will restrict fuel flow, would this explain no fuel getting to the engine? With the pump sounding as it should and no codes set, how can I be sure the problem is the pump? Any help out there would be appreciated. I have search this sight and found resolutions across the board for these symptoms. Is there anyone that may offer information targeting my specific problem?
