I was unable to find a tutorial so ill just do a quick write up (sorry no pics this time)
1)disconnect battery
2) take out the ashtray(little clip ontop inside)
3) unscrew the 2 screws holding in the plate the ashtray goes into
4) pull around the outside of the dash face? to remove clips but dont pull to hard (dont want to break it) dont pull to far
5) disconnect the 4x4/lowrange electrical connector,the rear wiper electrical connector,and rear defrost electrical connector
6)continue to pull its away (might be easier in 1st gear to get ther shifter out of the way) but dont forget the E-brake lol
7) there are little brass screws all around the clear plastic that covers the guages remove all of them (8 or so of them dont remember exactly)
8) Pull the cover away and very carefully pry up the gauges using a very small flat head screwdriver (they arent screwd in or anything they are pins in the back of the gauges that just slide into little holes(male/female) after prying it up then pull straight out
9) the bulbs will be pretty easy to change then just pull them out and push new ones back in
i had a little trouble getting the spedo guage out so i just worked around it i was affraid to pull to hard on it so u can reach behind it and pull them out (easier with smaller hands) i have big hands so it was a little bit of a p.i.t.a lol good luck and i hope this helps you out
