| Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum. |
Thread Tools |
#1 |
Wannabe Elite Explorer
nowhweree
'97 sport
Airbag code 42?
I am getting an airbag code 42 on my 02 Explorer.
I have tried to unplug and reconnect the yellow connecters under the driver and passenger seats. This does not work. It has been raining for four days, I believe it may be moisture related. What is this code and how do I fix or clear it? |
#2 |
Richmond, Virginia
'97 Aerostar XLT
Driver Side Crash Sensor Mounting Failure
Normal Operation The driver side crash sensor monitors the severity of a crash event. If the crash event is severe enough, the sensor will signal the restraints control module (RCM) to deploy the driver side air bag. The RCM monitors the two-wire current loop to the driver side crash sensor for a signal that is out of the expected range. If the RCM detects a signal from the driver side crash sensor, indicating a sensor mounting failure, it will store diagnostic trouble code (DTC) B2441 and flash a lamp fault code (LFC) 42 (or a higher priority code if one exists) on the air bag indicator. Possible Causes A driver side crash sensor mounting failure fault can be caused by:
__________________ Happiness: An agreeable sensation arising from contemplating the misery of another. |
#3 |
nowhweree
'97 sport
Thanks for the info.
Is this sensor mounted on the radiator? How do I access it to check it out? |
#4 |
Richmond, Virginia
'97 Aerostar XLT
It's behind the trim at the bottom part of the b-pillar.
#5 |
Bahamas
2002 XLS
I have been having a problem with my airbag light coming on for a year now, it blinks i think in sets of 3s for 3 times and stays on...unfortunately I dont think the dealership here in the bahamas know what they are doing. When they hooked the my 02 Explorer XLS to the computer it gave them a code (unfortunately, i dont know what code) but they told me thats the code for the pretensioner (dont know if i am spelling it right). So luckily it was still under warranty and they changed it for me but low and behold the light came on again .....went through the whole process again with the dealership and they tell me they have to replace the same part....IS THAT POSSIBLE or are they diagnosing it wrong? please anyone with any help???
#6 |
Elite In Memoriam
1999 XLT
The 3 3 light flash code .....
K: LFC 33/DTC B1933 - Passenger Air Bag Circuit Resistance High Normal Operation The Restraints Control Module (RCM) monitors the resistance of the passenger air bag ignitor by measuring the resistance between pins 6 and 7. If the RCM detects high resistance between these pins, it will store a Diagnostic Trouble Code (DTC) B1933 in memory and flash a Lamp Fault Code (LFC) 33 (or higher priority code if one exists) on the air bag indicator. Possible Causes A passenger air bag high resistance can be caused by: a poor connection or corrosion in the passenger air bag module circuits. an open circuit or high resistance in the wiring harness. an open circuit or high resistance in the passenger air bag module. an RCM internal concern. __________________ Al Franklin My truck My Quest for 30 RIP Al Franklin! 1947-2010. Gone but not forgotten! :( |
#7 |
Bahamas
2002 XLS
Hey Aldive...thanks for you help and information - I have no mechanic knowledge (female driver hehe), so this pretensioner they keep mentioning to me is it BS?
Now that I think about it, they never once asked me the pattern of the blinks nor do I think they ever checked that they were sooo quick to hook it to the computer and check and always told me the same thing.....now i remember the exact words.......they said the code is saying there is an open circuit so they said we have to change the pretensioner!!!!! Last edited by deluca; 05-19-2005 at 01:50 PM. |
#8 |
Bahamas
2002 XLS
I was wrong about the pattern of the air bag light, when I left work today I watched it and it blinks in sets of 3s for 4 times not 3 :-( does that mean its something different?
#9 | |
VANCOUVER ISLAND CANADA
2002 FORD EXPLORER XLT
Thank you
Thank you.
I have a 2002 ford explorer. I found my crash sensor bolt had been broken and the sensor was dangling against the rad. I re-attached the sensor with a 1\4 " bolt and remounted the bracked and the code 42 for my airbag went away. Not sure how the bolt broke though. I bought this unit used with the light on. Thanks again for the info. Quote:
#10 |
2004 Mountaineer Premier
So is the sensor for the Code 42 (blinks four times, pause, blinks twice) located on the B-pillar or in the bumper (front and center)?
Just asking as the one in the front bumper is all corroded yet the one in the B-pillar of the vehicle looks brand new. Also, is it the same part number for either sensor or are they different? Thanks. |
| Thread Tools | |
