Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Info on Speedometer bounce
Reply
Thread Tools
Old 04-27-2005, 09:54 PM   #1
efmoyer
Myerstown, PA
'96 XL
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I'm writing this just to share my experience with this problem and hopefully help someone
Problem:
96 Explorer: Speedometer slowly gets the bounce. First noticed it in higher gears shifting back and forth. After awhile the bounce gets worse, then transmission isn't sure when to shift. (Since the computer uses the speed sensor to know how fast the truck is moving) Sometimes stays in higher gear at a dead stop. Eventually, the speedometer does hardly anything and transmission has no clue what to do, pretty much undrivable, unless you shift manually and stay away from the highways.
Fix:
1. Started out by changing the speed sensor. (no change)
2. Pulled speed sensor out of transfer case leaving wires attached, removed plastic gear from sensor and attached cordless drill and ran the drill while the ignition is on. (NOT STARTED) Found that the speedometer worked nice and smooth. That eliminated the console and wiring. Only 1 thing left.
3. Changed gear in the transfer case that drives the speed sensor. (Change both plastic gears right away.)
Runs like a top.
efmoyer is offline   Reply With Quote
( Join the Elite Explorers )
Old 04-28-2005, 07:58 PM   #2
tonyd12345
Franklin, NH
tonyd12345's Avatar
'92XLT 4X4
Vehicle Specs
Quoted: 0 Post(s)
speed sensor
Does the 92 have this speed sensor thing? My speedometer was going kinds crazy during really cold weather this winter, but went to relatively normal until recently. Now it's starting to act up again.
__________________
Tony D. Franklin, NH 92 XLT 4X4(present).
2003 Excursion 4X4 Limited(wife's truck)
97 F150 4x4 (sold in '04)
"Liberal: a person so openminded their brains have fallen out."
Next time you start griping about the government, thank a vet for the right to do so.
tonyd12345 is offline   Reply With Quote
Old 05-04-2005, 06:22 AM   #3
imblue
Pittsburgh, PA
'96 XLT Control-Trac
Vehicle Specs
Quoted: 0 Post(s)
Quote:
Runs like a top.
You changed the gear in the transfer case too?
The one on the speed sensor seems easy enough, but how did you change the (brass?) one inside the case?
Clint
imblue is offline   Reply With Quote
Old 05-06-2005, 06:33 PM   #4
thebignewyorker
Unregistered
Posts: n/a
Vehicle Specs
Quoted: Post(s)
jumping speedo fix
hey guys i have a 95 explorer and have the same prob a few of my boys that own a tranny shop told me that there is a speed sensor in the axle also and there is an exciter ring in there with it if that is broken it can cause this prob its the only thing i can think of, i already replaced my ecu both speed sensors transfer case and axle and my gauge cluster so basically it became a process of elimination i yet have to fix the exciter ring thing i really havent found the time to take care of it but its my last hope and im prayin that it works cuz that bouncin speedo is pissin me off.
Old 01-27-2008, 12:16 AM   #5
willie8605
Stillwater, Oklahoma
1995 Ford Explorer Sport
Vehicle Specs
Quoted: 0 Post(s)
I have the same problem. I replaced the peed sensor and it didn't change much. In the process of replacing the speedometer. If that doesn't help I will change the gears, but as asked below..how do you change the gear inside the transfer case?
willie8605 is offline   Reply With Quote
Old 01-27-2008, 12:30 AM   #6
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 417 Post(s)
Welcome to this forum. You have to open the transfer case, so it's not a quick job like changing the gear on the end of the VSS. Check page 2 in my thread on speedometer gears for more information: http://www.explorerforum.com/forums/...=158739&page=2
BrooklynBay is online now   Reply With Quote
Old 01-27-2008, 07:15 PM   #7
thebignewyorker
Unregistered
Posts: n/a
Vehicle Specs
Quoted: Post(s)
Easy fix
Gents I spent hundreds of dollars on this problem... its been to the tranny shop, I replaced the sensor many times, the ECU and even the gsuge cluster and what finally worked is cleaning the harness that plugs into the sensor with electrical cleaner. Try it you have nothing to lose
Old 01-24-2009, 03:57 PM   #8
WOODMAN
LOS ANGELES
1992 EDDIE BAUER
Vehicle Specs
Quoted: 0 Post(s)
the harness? can you break that down for the mechanically impaired,please, cause my 92 bauer is bouncing and undrivable,and i don't have any money to throw at it.
WOODMAN is offline   Reply With Quote
Old 01-24-2009, 07:43 PM   #9
BrooklynBay
Brooklyn, NY
Vehicle Specs
Quoted: 417 Post(s)
Welcome to this forum! He's referring to the plug for the vehicle speed sensor. Here's a picture of it:
Old 01-25-2009, 05:42 AM   #10
thebignewyorker
Unregistered
Posts: n/a
Vehicle Specs
Quoted: Post(s)
Speedometer Bounce
Yeah thats the wire harness, just unpkug it and spray electrical cleaner inside it and the part that recieves the plug on the sensor. You should be all good. PLease post your findings afterward to help others. Thanks hope it works for you.
Old 02-04-2009, 05:35 PM   #11
1996FordExp4x4
Chicago, IL
96 XLT
Vehicle Specs
Quoted: 0 Post(s)
I have the bounce and my car feels like there is something banging, dragging, almost like it wants to go into 4 wheel drive. I have a 96 v6. Any advice would be appreciated. Often when the banging occurs, the bouncing is happening as the same time.
1996FordExp4x4 is offline   Reply With Quote
Old 02-04-2009, 07:22 PM   #12
96eb96
Albany, NY
96 EB V6 OHV 4WD
Vehicle Specs
Quoted: 29 Post(s)
Quote:
put 12 v electrical grease in this connector after you repair it. It keeps out moisture.
96eb96 is online now   Reply With Quote
Old 07-14-2010, 11:43 AM   #13
dennisst99
Woodland Park, CO
1996 XLT
Vehicle Specs
Quoted: 0 Post(s)
More Questions on speedometer bounce
Hi,
I recently had to swap out the transfercase on my '96 Explorer with a used one from a salvage yard. Everything works great except for the speedometer. I first noticed that it was slow to 'pick-up' between 0-20mph but then it started fluctuating wildly at high speeds as well. I replaced the sending unit with the one from my old tcase (it didn't have the problem) but the problem still persists. It currently "chews" through speedo gears about once a month and of course speed control and shifting are whacked!
I put my finger up in the hole for the sensor and noticed that I could spin the internal gear with my finger which seems a little odd to me. I looked at the pictures of the internals of the tcase on another post and it looks like there are bearings on the inside of the internal gear. Are these supposed to allow the gear to turn or are they supposed to fit into a detent on the shaft?
Thanks for any help,
DennisSt
dennisst99 is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
