Lift kit for the 2003 model | Ford Explorer Forums
Canberra, Australia
XLT V8 - 2003 model
Hi guys
Any news from Ford USA about a lift kit for the 2003 model explorer ??? I am desperate to lift mine and I know the previous kits can't work on the 03 model due to the different springs set up.
Any suggestions would be gratrefully received.
Cheers
Louise.
If i am not too mistaken i believe there is no lift kit available for the 3rd gen's as of yet.
Lift Kits
Superlift makes lift kits for 2003 Explorer Sport Trac. About $2,200
jus adapt a body lift to work with it. thats 3" right there
Not that it would work on a 2003 Explorer. The 2003 Explorer and Explorer Sport Trac have different suspension setups.
HI Scott
Many thanks for that, I'll contact Superlift and see if they can give me any advice.
Thanks again
Cheers
Louise.
No problem.
BTT. Any news? I've got an 04
None as yet. I keep getting the info that a Ranger kit will fit an Explorer, however you need to be careful to make sure all is OK. As I live in Australia, I really need to be sure all will be OK before I get one imported. So, no joy as yet. I did lift it 15ml with new tyres (whooopeee). Only 4 odd inches to go....
Keep in touch if you find anything.
Cheers
Louise.
All this Sport Trac and Ranger talk is errelevant, considering he has an 03 XLT. Those will not work. And don't hold your breath for a lift kit for the 02+, I don't see it happening.
I don't see how it would be possible for a lift kit to made for '02 & up Explorers. If I remember right the rear axle shaft passes through a hole in the frame.
The only thing that might be possible is a body lift as hiridin mentioned.
Damn the soccer moms & yuppies for wanting more comfort & rugrat room :fire: :fire: :fire:
It's possible, but the problem is it will be too expensive (like most IFS/IRS kits) for companies to make and they will not sell enough of them in the Explorer market to turn a profit.
Yea, I can imagine how much one would cost. I'm sure it would be cheaper to do a front & rear SAS.
'03 Explorer XLT 4-Door Lift kits
Hey everyone, I was reading everyone's reply's and saw that the 2003 Explorer Sport-trac lift kit from SuperLift will work and then someone said it won't work on the 2003 Explorer XLT 4-Door. So is it true that there just isn't a lift kit for this Explorer?
Well I live in Illinois and there's this lift kit shop by me called Attitude Performace and I'm going to call them tomorrow and ask them if they know of a lift kit for the 2003 Explorer XLT 4-Door and I'll let ya'll know if there is. Later...:exp:
there is a 2" now avalible for the third gen 4-door.
There is only a 2 inch lift from Rancho and it is a quick lift. It works with the shocks. Other than that NO LIFT for the 3rd gen and I can say that with 99% confidence and probably never will be. OH the Rancho lift system is about $800 for all four shocks. I may get one next spring/summer if I'm lucky.
One more thing there is NO LIFT for 3rd gen Explorers other than a Sport Trac.
Awesome, thanks SkanlaxJMO and Rammer24. I'll check out Rancho's site and take a look at their shocks. Later...:exp:
other than the rancho quicklift or buying ur own springs, theres no other lift available unless u fab ur own
(2 inches up front)
(Vs stock)
