- July 13, 2005
- Location
- NC
- Garner, NC
- 2019 F150
- Callsign
- N1LVN
Long story short, it all started when I drive my X into a 2-3 foot deep puddle (no, not on purpose). So, I gutted and cleaned the interior - good as new. I replaced the diff and tcase fluids (pond water in there), and of course, cleaned the underside.
After the "incident" I noticed an oil leak (RIGHT after). After some diagnosis, it turned out to be the rear main seal. Not wanting to take that on myself, I got it fixed. At the same time, they noticed the front axle leaking. OK, but not bad enough to fix. Now the pinion seal is leaking a bit, but again, nothing major. BUT, now I am doing about 10 mph, and punch it, and hear a loud clunk from the front end (sometimes 2 or 3) and then it's fine. Towing my boat, same thing. It REALLY felt like the front driveshaft, which is only 2 years old, but when that failed the first time,the truck wasn't even driveable.
Diagnosis by the dealer puts the problem *somewhere* in the front axle. Since I can really feel/hear it under my feet, I'm leaning toward the left half-shaft. They think something in there is slipping, and honestly told me that rebuiding it would be expensive, and I need to think about dumping too much into it.
A friend can help me replace the half-shaft without too much trouble, from what I see here. I'm just wondering if there are any experiences with what I am hearing. I don't know if I want to get into a problem in the front diff. If it is confined to the half-shaft, it sounds like not too bad of a job, and I can get a new one for under $100, after-market (Ford's is close to $400).
Does anyone have any recommendations/experiences, with this type of situation? What might I have to prepare myself for? If I have to get into the diff, I was thinking of just looking for used - but I'd certainly at a minimum go ahead and replace all of those seals at the time.
Thanks in advance,
-Scubajoe
Thanks in advance,
-Scubajoe
