#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Street Truck & Performance Forums > Street Trucks
Notices
Street Trucks Do you have an Explorer Street Truck? Something setup for the road with handling more of a priority than ground clearance? This is the forum for you.
1.25" wheel adapters/spacers....pros and cons?
Reply
Thread Tools
Old 08-07-2005, 09:11 PM   #1
delussional77
avon, ct
2001 explorer sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I recently got my set of 17" SVT rims installed on my explorer. I love the wheels look but i do not like how the offset has decreased the amount of "stance" the car used to have. The wheels seem to be further into the wheel well then before and i can already tell it's annoying me to look at. I thought it would be a simple solution to just get some 1.25" wheel spacers/adapters but i'm wondering what (if any) are the cons to using wheel spacers. Pretty much the only pro i can think of besides making it look the way i want is that it increases the overall wheel base width making it less likely to roll over.
Any reason i shouldn't put 1.25" adapters on the front and back?
Quick Edit: I'm referring to the 1.25" adapters that bolt up to the existing lug-nuts and then have their own individual studs that the wheel bolts up to. Did a search and saw a lot of negative flack being given for "spacers"...so just to clarify, i'm only talking about adapters.
delussional77 is offline   Reply With Quote
( Join the Elite Explorers )
Old 08-07-2005, 09:25 PM   #2
tjnap250f
Norwell,Ma
tjnap250f's Avatar
'98 xlt
Vehicle Specs
Quoted: 0 Post(s)
i have 1" adapters on my explorer with the same wheels as you. it makes the wheels look so much better. i got mine of an ebay based store online and when they cam the hub size was a little to small so i had 25 thoulsands of an inch shaved off andthey fit fine. i am sure if u get yours from the right place you wil not have to modify them to make them fit right. i have heard that spacers wear out ball bearing and stuff like that which is true because you are putting more stress on them. other than that if youmake sure the spacers are on tight and check them after 20 miles or so then you should be fine. i havent had any problems yet (knock on wood) and hopefully i wont.
__________________
//Alpine//JL\\Boston\\
Cardomain page
VBgarage
tjnap250f is offline   Reply With Quote
Old 08-07-2005, 09:33 PM   #3
Retrolantern
New Orleans, Louisiana
'01 Sport
Vehicle Specs
Quoted: 0 Post(s)
I ran 1" bolt on spacers on my ex... no probs....gave it that wide stance that I love.....only thing to consider is if the original bolts from the truck stick out past the "flush wall" of the spacer...you'll have to trim the bolts....unless of course your wheels have holes in back to compensate for this (my cobra r replicas did compensate)
__________________
01 White X Sport
Retrolantern is offline   Reply With Quote
Old 08-22-2005, 05:57 PM   #4
Saleen_SR71
San Jose, CA
'97 EB 5.0
Vehicle Specs
Quoted: 0 Post(s)
im running 2" spacers in the rear with 22's no problems thus far other than some rubbing on one of the tires but i think my shocks are bad, but with my sub box in there i have no rubbing anymore
__________________
My Ride
Saleen_SR71 is offline   Reply With Quote
Old 01-15-2011, 01:37 PM   #5
BrianDye
I'll have another...
Monroe, MI
BrianDye's Avatar
2006 XLT
Vehicle Specs
Quoted: 58 Post(s)
I'm gonna do some CPR and revive this thead,
Anywho, I'm in need of new tires but I was wanting to upgrade to some 20s maybe 22s this summer, but id rather just do it now rather than dropping 600$ for 4 tires, I've found quite a few pairs of rims I like with +70% tread matching tires. Some were 6x135 (F150 6 lug) style rims and I found a pair of adapters on CL for 140$. My qustion is this: you guys say it puts stress on the hubs and wears them prematurely....HOW much stress? Are we talking loosing 1000 miles off the hubs or somethin significant like having to replace them in a year (Mine are literally brand new, and about to have all 4 balljoints, tie rods, and uca's new too. Less than 50m on my hubs)
__________________
06 XLT
Debadged in back, removed pin stripe, tinted fogs, LED conversion, black headlights w/Morimoto Mini retro, xB LED Halos, black bentley style grille, 18" Fi BTL, Pioneer X4700BS, & plenty more
Check out my for sale posts here. 4th Gen Headlights, Grill, Flip Key, & H13 HID Kit.
BrianDye is offline   Reply With Quote
Old 01-24-2011, 02:31 PM   #6
syn-
orlando, fl
96 xlt - wip
Vehicle Specs
Quoted: 0 Post(s)
There is alot of user opinion in this option to run spacers. I have been told it will do many things that your not happy with ($ wise) down the road. That being said if you have replaced your parts with OEM expect that you will have a shorter life on your suspension as this was the not the intended setup by Ford. Same goes with lowing your vehicle, there is simply more stress then stock. With all that said, they are safe but be prepared to take your wheels off from time to time to inspect the spacers so you don't have a wheel fly off and race you down the highway. Also, with the whole hub life question, this depends on your ability to anticipate bumps, take it easy on short drive way dips, and counter the roads design flaws as needed to keep optimum life. With a stock setup the worry is not on you its on Fords engineering. As with the spacers (an aftermarket mod) the worry and ultimate failure of any front suspension in comes in direct contact is placed on your mind. So in short.
Yes: If you are mechanically inclined and plan to inspect your own tires and rotate accordingly (while checking the added spacers with studs as these are the only version you should consider).
No: If you think you can slap on an attachment that will make things fit without inspecting to ensure the safety of you and your future passengers.
__________________
Signature modified by Moderator
syn- is offline   Reply With Quote
Old 01-24-2011, 02:36 PM   #7
BrianDye
Monroe, MI
BrianDye's Avatar
2006 XLT
Vehicle Specs
Quoted: 58 Post(s)
I decided to skip on them. I'd LOVE a wider stance but it's just not worth it to me. Thanks for all that info though, I'm sure it'l help many more in the future.
I would just be worried everywhere I drive that somethings gonna fail on me
__________________
06 XLT
Old 01-25-2011, 08:54 AM   #8
syn-
orlando, fl
96 xlt - wip
Vehicle Specs
Quoted: 0 Post(s)
Not to beat a dead horse, but the chances of the adapters failing (spacer with attached studs) is all on your attention to keep the bolts tight. Now something I forgot to mention is that once you get them on some applications have you cut the existing lugs shorter so they do not come into contact with anything. A much more permanent "fix" if you ask me, though if you find yourself still wanting the stance go with the eibach spacers they are lug and hub centric but come with a hefty price.
__________________
Old 01-25-2011, 11:18 AM   #9
Saleen_SR71
San Jose, CA
'97 EB 5.0
Vehicle Specs
Quoted: 0 Post(s)
I would also say make sure your rear wheels have an offset that compensates for the rear spacer.
0 offset rims and 50mm spacer = not good for tire wear or rear end.
I say this from personal experience from my last set of wheels and tires.
__________________
My Ride
Old 05-31-2011, 07:16 PM   #10
Makahveli
Denver, CO
'92 Sport and AMG 300CE
Vehicle Specs
Quoted: 8 Post(s)
Though I have only driven my explorer 6 out of the last ten years I gotta say I have no problems with wheel adaptors, and on the rear I have adaptors over wheel spacers, no complaints here!!!
__________________
305/40r22 Nittos, KMC Rims, K&N, Granatelli MAF, BBK TB, Borla muffler & headers, Magnaflow Cat, 4" lift (Assorted Parts), 2 15" Eclipse Subs+Amps, 4.56 gear ratios, SCT 5 Program Chip, Warn Hubs, Paxton Supercharger SN2000, Port & Polished 95TM Heads+Lower Intake, 422 Cam, 30lbs Injectors, Snow Water Methanol Kit, Ready to Race!!!
IF YOU GOTTA BE A MONKEY BE A GORILLA
Makahveli is offline   Reply With Quote
Old 07-07-2011, 11:30 AM   #11
Bwad
Woodland, CA
1997 Ranger XLT
Vehicle Specs
Quoted: 0 Post(s)
I'm running the same setup on my ranger. 17" SVT rims, but mine didn't clear my truck's hubs so I was forced to run adapters. I went with 1.25" and am probably gonna get some 1/2 inch spacers for the rear as well. Some have said it puts strain on your wheel bearings, but if that's the case then so would running wheels with a lower offset...
Pic:
Bwad is offline   Reply With Quote
Old 01-07-2012, 09:21 PM   #12
delussional77
avon, ct
2001 explorer sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Wow guys, I made this thread 6 years ago and forgot all about it until today when I decided to sell the spacers that I had my explorer all those years ago.
The 1.25" did fit fine - and my SVT wheels did have the holes bored into the back of them to fit the studs (I can't recall if they stuck through or not, I don't think that they did).
I've long since sold my Explorer (after crashing it, unfortunately) - but have had the wheel spacers for years. Time to get rid of them.
Old 03-19-2013, 12:28 AM   #13
Grizzly2012
2005 mercury mountaineer
Vehicle Specs
Quoted: 0 Post(s)
Do you still have the wheel spacers for sale? I know its been over a year but it doesnt hurt to ask.
Grizzly2012 is offline   Reply With Quote
Old 11-20-2014, 10:50 PM   #14
rabbit91
Surrey
2000 V8 lifted 33s
Vehicle Specs
Quoted: 44 Post(s)
Bumping this because I'm getting spacers, 1.25inch. Anyone have a brand they have been happy with?
__________________
Brad
2000 Limited - SAS'd JK D30 (explorer hubs), SOA, Manual Tcase, truetrac rear , front bumper, sliders, 33s, sloped body lift
rabbit91 is offline   Reply With Quote
Old 01-14-2015, 07:53 PM   #15
Blacksheep Josh
Slinky+Escalator=Fun
Statesboro, GA
Blacksheep Josh's Avatar
'01 Ford Ranger, RIP 93 X
Vehicle Specs
Quoted: 13 Post(s)
Won't lie, I went with eBay on mine. But I didn't look for the absolute cheapest kind. They've worked well and with no issues for 2 years now.
__________________
I haven't been on this forum in a while and I'm trying to work my way back into it. I'm going for Mod or bust!
"Thunder" Registry R.I.P. 2005-2012
2001 Ford Ranger Edge 5.0L Swap Thread
1991 Nissan 240sx Drift Pig
Blacksheep Josh is offline   Reply With Quote
Old 03-15-2015, 09:47 AM   #16
03Sport
Augusta, GA
2003 Ford Explorer Sport
Vehicle Specs
Quoted: 24 Post(s)
I just bought some 1.5" off of eBay and didn't realize they weren't intended for stock wheels. Still deciding if I want to use them without my hub cap or just sell them.
03Sport is offline   Reply With Quote
Old 04-17-2015, 04:20 PM   #17
X~FACTOR
Name is Ray
Valley Stream, Long Island
X~FACTOR's Avatar
'97 XLT 4-dr SOHC
Vehicle Specs
Quoted: 47 Post(s)
Quote:
Knowing what I know now, I should've bought spacers as my first mod. lol
__________________
My Mods
X~FACTOR is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
