1992 Explorer | Ford Explorer Forums
1992 Explorer
AKBroncoII
Anchorage, AK
Kind of new to the forum. Signed up a while back but haven't posted much.
Explorer specs. mostly stock 4.0, built A4LD, manual 1354, HP44 front, 9" rear. Front has 5.13's, ARB, high steer. Rear is detroited, 5.14's with a currie case, disk brakes with caddi calipers. 4" custom Alcan leafs in the rear. 5.5" BC bronco's EB springs in the front with custom coil buckets. 1 ton drag link end steering. AC pump converted to on board air run to rear bumper. Tires are 36x12.5x15" TSL SX's.
I don't have a whole lot of pics of it. I usually go by myself and I don't have a camera.
This winter it's getting a 5.0 HO swap, AOD to NP208, HP 60 front with the same gears and locker as now, and a dana 70 rear with the same as now. I am also going to do a full exo and probably run 38's or 39.5's.
Dang, that's sick. What are you gonna do with the 44 and the 9"/
now thats how an ex should look :thumbsup: ...keep up the awesome work...be sure to take pictures and post of all your progress...i'm very interested in seeing it as I share the same plans...
TTIUWOMP! (this thread is useless without more pics) :D
Looks awesome. I have very similar plans as far as axles and motor go, but I'm just going to stick with the d44/9" combo and 36-37s. If you could get some more pics, that would be awesome. :)
I would love to get more pics. But I didn't take those even. A friend of mine did. I don't have a camera. The 44 and 9" will make it's way into my bronco II, along with the motor, tranny tcase from the explorer. I already have the axles built for this winters swap and my motor.
Do you have any plans for flares? APD mess with you about them yet?
You should post a pict of your Bro's B2 :thumbsup:
No problems with APD yet. I do have rear mudflaps. I have plans for flares. But not until the 60 goes under it. I need to see what I'm going to have to trim to get the 38's to fit
incredible, masterful
that looks soo cool, i wish i could afford a fw sas
Wow! That's awesome!!!
Something like that makes me want to get a Explorer! lol
Mickey
that's a very sick looking ex!!!
Has anyone ever put a 70 under the explorer before? A 60/70 combo is gonna be SAAWEEET!!!!
ive got either a D60 or 14bolt under my explorer right now, gotta decode the axle to find out what it is, owner said it was a 14 bolt, but its got the ford slight offsetpinion output which tends to lean towards ford origin
I am doing one in a couple of months. Already have the axles. Just waiting on my transmission to swap in the 5.0L as soon as I can get her IMed one last time.
How much did it cost you in parts to do the D44/9..?
Looks tempting...TTB sucks
It cost me quite a bit. I probably have about $2500 into the front. And around $1500 into the rear. That is no including springs. My springs were $225 for the fronts and around $500 for the rears.
i call dibs on the manual 1354 if you sell it :D
that is full width right?
