- November 11, 2005
- Brooklyn, NY
- 88 89 93 95 96 Aerostars
Band specification chart.
A4LD:
All Intermediate bands are single wrap. Single wrap band = 2.0 turns back.
1990-1992 Overdrive bands are double wrap, except in mid 1992, which went back to the single wrap band. Double wrap band = 3.5 turns back.
4R44E/4R55E 5R44E/5R55E/W/S/N:
Single wrap bands.
Overdrive band = 2.0 turns back.
Intermediate band (1995-1998) = 2.5 turns back. All other years 2.0 turns back.
The procedure for adjusting the bands is as follows:
Loosen the nut on the adjusting stud while holding the stud in place. Set your torque wrench to 10 ft.-lbs. (120 in.-lbs.), and tighten the stud. When it reaches 10 ft.-lbs. refer to the above specifications to set the proper amount of turns back. Hold the stud in place, and lock the nut to 35-45 ft.-lbs.
A4LD:
Single wrap bands.
