#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Technician's Tips and Tech
Notices
Technician's Tips and Tech This forum is where professional automotive technicians or skilled automotive hobbyists can share their tech tips. Do not post your questions here! Post in the forum best suited to your topic. Questions posted in this forum will be deleted!
TSB 05-12-6 2002 Explorer Rear End Whine
Thread Tools
Old 04-28-2006, 09:19 PM   #1
ExplorerDMB
Moderator/Technician
Mechanicsville, Virginia
2004 Acura TL
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Post TSB 05-12-6 2002 Explorer Rear End Whine
Ford Explorer Rear End Whine/Hum
TSB 05-12-6
Vehicles:
2002-2005 Ford Explorers
2002-2005 Mercury Mountaineers
Issue:
Some vehicles listed above may have a whine/hum during acceleration, deceleration, and/or cruise.
Action:
Use axle repair kit to fix the issue. This kit should be used instead of installing a complete rear axle assembly. Replace the Ring and Pinion and it's components.
NOTE: When servicing the rear axle on these vehicles, replace the 75w-90 gear oil with 75W-140. If the axle is equipped with a Limited Slip, add the required amount of friction modifier (XL3). When replacing the fluid, replace metal tag with F3TZ-4121-AA tag.
Kit Part Numbers:
  • 8.8" 3.55 Gear Ratio - 5L2Z-4209-AA
  • 8.8" 3.73 Gear Ratio - 5L3Z-4209-C
Time: 6.6 Hrs for Explorer/Mountaineer
-Drew
__________________
My Useful Threads (38 Entries and Growing)
ExplorerDMB is offline
( Join the Elite Explorers )
Old 08-08-2006, 01:12 AM   #2
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 380 Post(s)
These links have additional information: http://www.explorerforum.com/forums/...d.php?t=138420
http://www.fcsdchemicalsandlubricant.../tsb/05126.pdf
BrooklynBay is offline
Old 10-25-2007, 11:30 AM   #3
tv4fish
Minnesota
2007 EB V8 & 2002 EB V6
Vehicle Specs
Quoted: 1 Post(s)
Was this whine/hum supposedly covered by Ford at no charge to owner ??? I've had this problem on my 2002 Explorer (Eddie Bauer) since new and was never notified by Ford that they would fix it. I've had tranny serviced twice and rear-end once and it's still there??? If Ford was supposed to fix -- I'm MORE than a little PO'ed ???
tv4fish is offline
Old 02-02-2008, 10:32 PM   #4
SnookMan
Miami, FL
'02 XLT V8
Vehicle Specs
Quoted: 0 Post(s)
I just bought an '02 XLT 4.6L, and the whine is ridiculous!!! I drove it home from Tampa and thought the rear end was going bad or something. It went as far as me calling the seller and cursing him, etc.....
So here I am looking for info on this truck and come across this. If this is a technical bulletin from Ford, will they fix this problem? I'm assuming changing the fluid in the rear end doesn't fix it? I was thinking that the guy I bought it from changed the fluid and didn't put the additive in or something, or maybe that the wheel bearing was bad, etc.
Any advice would be greatly appreciated
SnookMan is offline
Old 02-02-2008, 11:08 PM   #5
JosephB
Bedford, Texas
2000
Vehicle Specs
Quoted: 0 Post(s)
Your whine
i had similar problems except mine kinda roared only when i turned. The problem i ran into is i had to re grease the rear differential. I'm not sure if yours is doing the same.
JosephB is offline
Old 02-05-2008, 12:49 AM   #6
mccoya
Vehicle Specs
Quoted: 0 Post(s)
what is the cost for this to be done on avg?
mccoya is offline
Old 03-08-2008, 04:38 PM   #7
walshb
Awaiting Confirmation
Woburn, MA
2004 Limited
Vehicle Specs
Quoted: 0 Post(s)
US 04 Explorer rear end problems
I am having similar problems with my 04 Explorer. I hear a low pitched whine when coasting down a highway exit ramp. In other situations I hear and feel a low shudder and vibration when turning left or right from a stop sign or light. I have replaced the front axle half-shafts as it seemed the problem was in the front end. Does anyone know what is causing these problems and how I can I repair them? Are any of them covered by Ford recalls? Thanks.
walshb is offline
Old 04-15-2008, 10:10 PM   #8
hanster24
Mentor, Ohio
2000 XLT
Vehicle Specs
Quoted: 0 Post(s)
dude, thats what my 2000 xlt is doing? whould this work for me? is it under warrenty? and what is the 8.8 5.37 .37 ?
hanster24 is offline
Old 04-17-2008, 04:17 AM   #9
dqsdad2001
Weyers Cave, VA
dqsdad2001's Avatar
2004 XLT
Vehicle Specs
Quoted: 0 Post(s)
Quote:
Just had the rear ring and pinion changed on my 2004 X. The selling dealer was stuck with the bill though. It cost a little over $1100 at my local ford dealer and comes with a 12month 12,000mile warrenty.
__________________
Sean Shannon
2004 Explorer XLT , 2006 Scion XB
1953 Ford F100 (454ci) I know thats a chevy motor but its fast
http://profile.imageshack.us/user/dqsdad2001/
dqsdad2001 is offline
Old 04-17-2008, 04:35 AM   #10
dqsdad2001
Weyers Cave, VA
dqsdad2001's Avatar
2004 XLT
Vehicle Specs
Quoted: 0 Post(s)
Quote:
The rear end whine I was having came in after the rear was warmed up and started around 55mph and got worse the faster I went. If I would let off the gas pedal the whine would go away until I pressed the gas pedal again. Your low pitched whine might be something else. I signed up for www.alldatadiy.com. The info supplied, I thought was well worth the money. See I was dealing with a Used Car Salesman that gave me a 1 month/1000 mile warrenty when I bought my X. When I test drove it I didn't hear any noises but when driving it home from work the next day is when it showed itself. I used the alldatadiy service to educate myself to deal with a used car salesman that was telling me nothing was wrong with my X.
__________________
Sean Shannon
Old 04-19-2008, 05:40 PM   #11
jpserra
Plymouth, MN
2004 Explorer XLT
Vehicle Specs
Quoted: 0 Post(s)
Once again;
What is the cost?
Is Ford supposed to cover this?
JP
jpserra is offline
Old 04-19-2008, 07:25 PM   #12
dqsdad2001
Weyers Cave, VA
dqsdad2001's Avatar
2004 XLT
Vehicle Specs
Quoted: 0 Post(s)
Quote:
Originally Posted by jpserra View Post
Once again;
What is the cost?
JP
Cost is above here it is again...a little over $1100.00
Ford will not cover this.....unless you are still under the manufacturer's warranty or have an extended coverage.
__________________
Sean Shannon
Old 04-28-2008, 06:12 PM   #13
RedJeep
Ohio
03XLT 4.6 & 15 Unlimited
Vehicle Specs
Quoted: 3 Post(s)
Rear end whine
My 03XLT 4.6 trailer tow package, limited slip got the whine at 21,000 miles.
Dealer changed out ring,pinion and bearings (under warranty) Went out again at 42,000 miles and 4 years 7 months old. Dealer did the same again for $200
bucks and another 12 month warranty on it. Should never have happened but
my dealer is a keeper. Don't know if they ate the rest of cost or Ford is repaying them. I only had the standard 3 year warranty on car. Anyway with that kind of service guess where I will buy next vehicle.
RedJeep is offline
Old 04-28-2008, 07:47 PM   #14
walshb
Woburn, MA
2004 Limited
Vehicle Specs
Quoted: 0 Post(s)
Explorer rear end noise
Thanks to all for your input. As my vehicle is way beyond a warranty period I did some more research into the problem. Ford now recommends changing the rear differential gear oil to a 75w 140 synthetic. I did this yesterday and it works rightout of the gate. The noise and vibration are gone. No telling how long it will last. I will keep you all advised of the situation.
walshb is offline
Old 06-04-2008, 06:49 PM   #15
Hitchhikingmike
Dallas, Texas
'02 XLS
Vehicle Specs
Quoted: 5 Post(s)
Interesting, the TSB says to replace the 75w-90 gear oil with 75W-140, my haynes manuel, which was published in 2004 for my 2002 explorer says to use 75w-140 without even mentioning anything about 75w90.
My explorer's owner's guide book says to use 75w140 too and mentions nothing about 75w-90. My owner's book was published in June of 2002 and says 6th printing. This might mean that this is the 6th revised version of owner's manual for the '02 explorer. I assume then that my explorer came with 75w-140 from the factory
It appears that sometime during the production of 2002 explorers on the assembly line, Ford probably switched all their gear oils on the explorer to the 140 in reaction to the rear end whines.
I guess if anyone has a early production '02 explorer who is still running off their factory 75w-90 oil they should immediately switch to the 75w-140, as it appears that Ford has abandoned the 75w-90 on the later '02 explorers.
Hitchhikingmike is offline
Old 07-22-2008, 02:34 PM   #16
brockdog08
Dallas, TX
2006 Mountaineer
Vehicle Specs
Quoted: 0 Post(s)
Ford replaced my rearend at no charge to me when I owned my 2003, out of warranty. My 05 is not doing it, but I bought it used so someone may have had it repaired already, I haven't looked to see.
brockdog08 is offline
Old 07-27-2008, 03:09 AM   #17
wickedturns
California, Salinas
2004 Ford Explorer
Vehicle Specs
Quoted: 0 Post(s)
just to inlighten you all a little , I work for Right Gear And Axle, out of Salinas, Ca. We deal with drive lines, and gears Daily. 90% of all customers that complain of a shutter usually need an oil change. the clutches in the posi need an extra addative to allow slipage. the oil we use that is very safe is an 80w140. with a GL5 rating. customers with a cuntinous whine usually need new brgs or gear set . this repair usually runs between 500 and 700. , never ever go to a dealer to make this repair. if possible look for a specialty shop. dealers always times everything times three! I know I sale to them daily.
wickedturns is offline
Old 08-10-2008, 10:42 PM   #18
andypinto
Arica, Chile
92 XLT, 2002 XLT
Vehicle Specs
Quoted: 1 Post(s)
Hello everyone:
I have the infamous whine too. My 2002 Explorer XLt 4x4 has 108.000 miles and the humming sound only occurs when is in acceleration and comes on abot 40 mph and goes off over 75mph.
After a quick search in the web I found this information:
http://www.ford-trucks.com/tsb/fullt...hp?tsb=05-23-3.
According to that wesite, Ford issues a new TSB 05-23-3, which supersedes TSB 05-12-6 mentioned by ExplorerDMB.
Hope it helps.
__________________
Andy
Arica, Chile
92 Explorer XLT 4x4, mostly stock
Blaupunkt Las Vegas, Lund bug deflector, Bosch Pilot 150 fog lamps.
2002 Explorer XLT 4X4 AUT. 4.0, Blue, a/c, c/c, sunroof, premium sound system,HID Xenon headlamps.
My Mug
andypinto is offline
Old 08-10-2008, 11:53 PM   #19
wickedturns
California, Salinas
2004 Ford Explorer
Vehicle Specs
Quoted: 0 Post(s)
Bearings, Bearings, Bearings. towing and reg,. day diving causes ware. replace brgs and get it out of the way!!! check for specialty shops so your not over charged...
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
