sn0border88
Master Apprentice
- June 27, 2005
- Souderton, PA
- 1992 XLT
I recently did some work to the 4.0, removed radiator to pressure wash and flushed system. Did minor cleaning of everything under the hood to try and get the mud and grime out. Anyways, I dont drive it much as of alte because I walk to work. When I do drive it, it goes all kinds of wierd. its fine in 1st and usually 2nd gear, but if I feather the throttle, or anywhere under half throttle it bogs down to about 1300-1500 RPM and if I give it a little more gas it will jump back to 2000-2300 only to drop down again very shortly. It never does this under WOT and once the engine warms up I dont really notice it either.
At first I thought it was the trans, but I have also noticed an unsteady idle. When sitting at a stop light it bounces around 500-700. Sounds like I have a really agressive cam. As soon as it goes into park it idles a little high, 1000 or so but will soon start bouncing like I said earlier. After about a min it kicks up real high to 1200 or so and stays there until I give it a little gas, in which the previous process resumes.
No other problems noticed cruising in OD or really anywhere over 45.
WTF is going on?
I do have an intermittent CEL but I havent seen it in a while. My code puller is broken and I suck at it anyways so if you guys dont ahve any better ideas I may take it to a shop and have them pull em.
WTF is going on?
