Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
transmission drain plug
Reply
Thread Tools
Old 08-30-2006, 10:05 AM   #1
swandog
Mpls, MN
'00 xlt
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Question transmission drain plug
Has anybody installed a drain plug in their transmission pan? If so where do I find such a thing? I looked at autozone the other day but didn't see one... I need to drop the pan here in a couple of weeks (oil/filter change) and I would like to make it easier to change the trans oil (or at least some of it). Not sure how many miles I have left in the tranny but I would like to squeeze out as many as possible...
Thanks
Doug
'00 Exp sohc V6 4x4
swandog is offline   Reply With Quote
( Join the Elite Explorers )
Old 08-30-2006, 10:50 AM   #2
Rick
Admin
Pumpkin Pilot
Wayoutin, Aridzona
Rick's Avatar
'93 XL Pumpkin Edition
Vehicle Specs
Quoted: 425 Post(s)
They don't install a plug from the factory, because it's much better to change your filter at the same time.
If you're having problems with the tranny slipping, changing the fluid will make it worse. New fluid is loaded with detergents which will eat up worn clutch surfaces.
__________________
Rick Horwitz, AB7FH "Serious Exploration's" Admin
Rick's '93/'98 Explorer "The Great Pumpkin"
Dodge Dart 512 Resto/Race 10.29 @ 129
2004 Mustang Mach 1
1960 Dodge Dart Seneca
Rick is online now   Reply With Quote
Old 08-30-2006, 10:50 AM   #3
Rick
Admin
Pumpkin Pilot
Wayoutin, Aridzona
Rick's Avatar
Vehicle Specs
Quoted: 425 Post(s)
Welcome to the site
__________________
2004 Mustang Mach 1
Old 08-30-2006, 02:07 PM   #4
JNICHOLS
Port Angeles, WA
2000 XLT
Vehicle Specs
Quoted: 0 Post(s)
I put one in my old S-10 Blazer a few years back (I know this is a Ford site...but the Blazer was free!). I always change the filter with the fluid, but having a drain plug makes the process so much cleaner. I prefer to put a plug in the rear of the pan as often times the front of the vehicle is higher than the back when working under. This allows the more of the fluid to drain out before you drop the pan. You can make you own with a pipe nipple and some fittings or order one of the aftermarket ones like this one http://martelbrothers.com/product.ph...3621315d5b50b8
Good Luck!
JNICHOLS is offline   Reply With Quote
Old 08-30-2006, 02:19 PM   #5
spindlecone
B
San Jose, Calif
2003 sport trac
Vehicle Specs
Quoted: 0 Post(s)
Plugs are nice, makes for less grief when dropping the pan, just a suggestion, take it to a welding shop and have it brazed in,JMO
spindlecone is offline   Reply With Quote
Old 08-30-2006, 02:24 PM   #6
410Fortune
ELITE BRONCO2ERER
Crawlorado
410Fortune's Avatar
B2 Mod
Vehicle Specs
Quoted: 3 Post(s)
My drain plug also doubles as the port for my temp sensor.
The drain plug is nice because you can do a filter and fluid change, which gets about 4 quarts of fluid out, then you can drive for a bit and drain the pan again, etc, eventually getting all the fluid to run red again....
But Rick is right it is best to change the filter and the fluid at the same time.
Having it welded to the pan is the best way, but mine does not leak without it, I used an anabolic sealer (permatec) on the inner and outer plastic washers, no leaks at all.
Most speed shops or GOOD auto parts stores will stock these drain pan plug kits
__________________
96 Explorer daily driver build-1996 XLT 5.0L AWD to 4x4 conversion complete on 33's
88 BII 5.0L conversion - BII 5.0l drivetrain thread
My Bronco II - 1988 Bronco II 4x4 V8 on 35's - registry and updates
Wifes 07 FJ build - 2007 FJ cruiser locked and lifted
410Fortune is offline   Reply With Quote
Old 08-31-2006, 01:48 AM   #7
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 411 Post(s)
I have previously used drain plug kits, but had problems with leaks. I prefer to solder a nut inside of the pan, and use a magnetic drain plug. The drain plug kits use a small plug which makes it difficult to drain all of the ATF at a fast rate. I've also soldered nuts inside of my differential cover to fill, and drain the fluid.
BrooklynBay is offline   Reply With Quote
Old 08-31-2006, 02:24 AM   #8
BrooklynBay
Brooklyn, NY
Vehicle Specs
Quoted: 411 Post(s)
This is a picture from post #4's link:
Old 09-01-2006, 09:48 PM   #9
slpdave
Lenoir City, Tennessee
2000 XLT
Vehicle Specs
Quoted: 0 Post(s)
on my old Camaro (insert redneck/Chevy joke here) I installed a tranny drain plug. got an aluminum drain plug at Advanced auto parts, took it to work (we had a machine shop and welding shop at that job) machined a hole at the back of the pan, welded the aluminum plug into the aluminum pan (not brazed) threw away the rubber O ring and put a crushed metal seal (basically fancy solder that meshes and seals and is more resistant to heat than rubber). and the tranny changes became a clean job instead of dirty.
One hint (I learned this the hard way) don't put it on the absolute bottom, if there is a place on the back side put it there, then it won't get hung on stuff.
David
slpdave is offline   Reply With Quote
Old 02-15-2011, 04:33 AM   #10
crunchie_frog
Lexington, SC
2000 5.0 AWD XLT
Vehicle Specs
Quoted: 73 Post(s)
Hi Doug,
Here is a link for one at autozone. http://www.autozone.com/autozone/acc...ntifier=103014
I have put in several of these over the years. It makes it much easier and cleaner to drain and then you can pull the pan and change the filter. I have never soldered or brazed them in, but have never had any leaks either. I have always smoothed both sides of newly drilled hole using a wetstone so there are no burrs, raised edges, or irregularities that would prevent the washers from making a good seal. Good luck.
crunchie_frog is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
