badge49
- September 8, 2005
- Humboldt, CA
- '97 XLT 4X4
I finally finished gathering the parts and installing everything for a dual battery system! I now have an Optima Red Top as my designated starting battery and an Optima Yellow Top as my deep-cycle accessory battery. I bought a Sure Power 120A power isolator on Ebay and used no less than 8 guage wires to make all the connections. Instalation was surprisingly easy and only took one afternoon. I definitely recomend this to anyone who goes camping or wants to run heavy draining accessories off their truck. Be sure to get yourself a good voltometer and check your current levels at each connection. Also be sure to secure everything tightly as you mutiply the number of "hot" wires and the points where they could short circuit if left loose. The last thing you want to happen is to run a 24V system and fry your electrical! I currently use this system to run a 115V AC power inverter so I can take my power tools with me on the go. Since the install last week, I've noticed I don't have as much dimming of power when I run multiple accessories (fog lights, radio, amp, cb...). I also plan to run a winch off the accessory battery in the future. The best part of the whole thing was watching the expression peoples' faces when I "jumped" myself the other day after running my stereo for almost six hours with the truck off! A definite necessity for serious explorations in the future! Here are a few pictures of what it looks like:
This is the deignated starting battery with a power line running to the isolator.
This is the Sure Power 120A isolator, mounted to the passenger wall.
Here's the Yellow Top tucked in behind the passenger headlight.
And here's the overall new unit, you have to relocate a bunch of stuff, but it will fit. Next on the list: tire/jerry can rear bumper, then on-board air! :navajo:
