Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Any help on how to install a new starter?
Reply
Thread Tools
Old 02-14-2007, 11:36 AM   #1
dlo
Randolph, Maine...Back home baby!!!
96 XLT
Vehicle Specs
(Original Poster)
I did a few searches and nothing. Does anyone have info to a link, picture thread or even some quick info they can give me on installing a new starter on a 96 4.0 with an auto tranny?
Thanks all.
__________________
As my wife would say : I have an un-exquisite taste in homo-lific autos
dlo is offline   Reply With Quote
Old 02-14-2007, 12:09 PM   #2
97greenmonster
B
Omaha, NE
97greenmonster's Avatar
'97 Ford Explorer XLT 5.0
Vehicle Specs
Its really easy. As simple as taking the 2 bolts of, and disconnecting the cables. But be careful, the top bot is a pain in the but to get at, there pretty tight, me and my stepdad had alittle bit of trouble getting at it, but we didnt have the right tools. Youll also need a deep welled socket.
97greenmonster is offline   Reply With Quote
Old 02-28-2007, 12:53 PM   #3
dlo
96 XLT
Vehicle Specs
(Original Poster)
I jus got the starter in the mail and am going to attempt it this weekend. Hoping for No snow and fairly decent weather. Always sucks putting your truck on ramp and being on the ground at 20 degree's out. Wish me luck
__________________
Old 02-28-2007, 02:16 PM   #4
97greenmonster
B
Omaha, NE
Vehicle Specs
HA, i didnt have to put it on ramps, it would be easier off them i think so you have more leverage cause its up high enough under the truck. If you go through the wheel wells to, that might be easy too, i just went right under the trucl with a deepwelled socket and a couple of extensions and got it off.
Old 02-28-2007, 05:55 PM   #5
marragtop
balt, md
91 xlt, 92 xlt, 95 xlt
Vehicle Specs
Try leaving the wheels on the ground and go thru the wheel well to get to the bolts. Make sure you disconnect the batt first (duh!).
__________________
'88 F150 4x4
'91 Explorer XLT 4x4
'92 Explorer XLT 4x4
'95 Explorer XLT 4x4
If it don't = 16 (4x4), it ain't worth driving...
marragtop is offline   Reply With Quote
Old 02-28-2007, 06:25 PM   #6
Nocturnall
Tempe, AZ
1997 Sport
Vehicle Specs
I used a normal metric socket (13mm IIRC) u joint, 6inch or so extension, another ujoint another extension, socket. Worked pretty easy, I left the wires connected till I unbolted it from the block then you can turn it and look at the wires as you do it. I did it with my truck on the ground but parked over a low spot in the grass so I had a little more room. Or should I say got towed and dropped over a low spot. Took 20mins to take out, maybe 30 to put in and it was my first.
Nocturnall is offline   Reply With Quote
Old 03-05-2007, 02:54 PM   #7
dlo
96 XLT
Vehicle Specs
(Original Poster)
Okay, so the update is she died the other night and I had to do the typical "hammer to the outside of the old starter to get the brushes to release" maneuver and I am soooo gonna pay someone to replace the starter after seeing where it is located.
Best damn $50 bucks I am gonna spend (will be done as of 3/6 in the am)
Can't wait to get the truck running again.
__________________
Old 03-05-2007, 03:25 PM   #8
Nocturnall
Tempe, AZ
1997 Sport
Vehicle Specs
If we lived closer to each other I'd do it for you.
Old 08-01-2009, 11:13 AM   #9
hammer57
Brandon, Manitoba
1996 Explorer XL
Vehicle Specs
What side wheel well? Driver or passenger?
hammer57 is offline   Reply With Quote
Old 10-04-2009, 10:55 PM   #10
BrianDye
Michigan
BrianDye's Avatar
04 CV LX Sport
Vehicle Specs
Drivers side.
Im trying to replace mine, got the bottom bolt with the ground wire off, but I CANNOT get that other bolt off, ive tried going through the engine area, and nothing, tried going through the wheelwell, and I cant get it!
I have the 13mm socket on the swivel adaptor, and right at the wrench are the extentions, so am I doing something wrong?
(Socket wrench > extension(s) > swivel piece ? 13mm socket) is how im trying.
__________________
'13 Dodge Charger RT
BrianDye is offline   Reply With Quote
Old 10-08-2009, 09:10 PM   #11
BigBoom
Kentucky
01 Sport
Vehicle Specs
funny that this got bumped. i'm thinking i have to do this myself. broke down about 30 minutes from my house at a mall lol. and i work doubles for the next 2 days, then a morning shift. i hope it doesnt get towed. but it doesnt turn over, just one click. lights and all are fine. some other research says that it's possible that it might not be the starter tho. but ima call around tomorrow.
EDIT: wait...further research shows that came from a 'not so smart' shop. so i'm going back to thinking it's the starter
BigBoom is offline   Reply With Quote
Old 10-09-2009, 03:41 AM   #12
marragtop
balt, md
Vehicle Specs
Is the clicking sound coming from the starter? If so, try smacking the starter with a hammer. SOmetimes that will get it to where it will start. You could also use a test light to verify that you are getting power to the starter.
__________________
'88 F150 4x4
Old 10-09-2009, 05:40 AM   #13
BrianDye
Michigan
BrianDye's Avatar
04 CV LX Sport
Vehicle Specs
Its just one CLICK when you turn the key, lights stay on, mine actually dim pretty good, but then you let off they key and its one more CLICK. Ive had it where my battery was low and it sounded like a toy tommy gun click click click click click like 90 miles an hour.
I STILL cant get that bolt off!
__________________
Old 04-01-2010, 07:35 AM   #14
9blackex1
Skokie, IL
1991 Explorer XL 4x4
Vehicle Specs
Brian urz sounds more like a low battery. or dead battery. One click= starter. multiple clicks = battery. even with a jump a dead battery will cause a no crank or a "tommy gun" starter sound
9blackex1 is offline   Reply With Quote
Old 04-01-2010, 07:38 AM   #15
BrianDye
Michigan
BrianDye's Avatar
04 CV LX Sport
Vehicle Specs
Old thread..lol I dont have that explorer anymore, but it wasnt the starter, it was the cables. All I did was wiggle the cable and it would crank right up.
I would never change a starter on these things though, call me stupid but after about 4 hours of trying for one bolt, thats it for me lol.
__________________
Old 04-06-2010, 07:49 AM   #16
9blackex1
Skokie, IL
Vehicle Specs
yea i know old post but meh.... i was looking for starter info and i saw the thread ha ha
Old 04-27-2010, 12:06 PM   #17
Cryptman
Colorado
95 Eddie Bauer
Vehicle Specs
US Short 1/4"
I used a short 1/4" ratchet with a deep 13mm socket and had no trouble getthing the bolt off. Just need to get in between all the junk. Problem that I'm having, now, is that I can't get the started out. It keeps getting jammed up, no matter which way I twist and turn it. I'm hoping I don't need to drop the driveshaft or differential. Anyone else have this problem?
Cryptman is offline   Reply With Quote
Old 07-18-2010, 11:15 AM   #18
arizonie602
Phoenix, Arizona
1994 XLT 4X4
Vehicle Specs
Just did my starter not to bad layed under the driverside was able to get to both nut and bolt with no problems..was a 14mm socket though and a 17mm for the bottom bolt..
arizonie602 is offline   Reply With Quote
Old 02-03-2011, 10:44 AM   #19
TheVarmit
Panama City, Florida
2001 Limited & 1996 XLT
Vehicle Specs
Quote:
I have the same problem getting my starter off my 1996 Explorer 4.0 . Don't let this thread die until I get an answer, PLEASE!!
TheVarmit is offline   Reply With Quote
Old 03-04-2011, 02:08 PM   #20
Alexb
Minnesota
1995 Eddie Bauer
Vehicle Specs
I got my starter off but can't get it out all the holes are to small for the starter to fit through.. Any advice?
Alexb is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
