bwingler
- February 23, 2007
- Acworth, Ga
- 93 Eddie Bauer
Hi all, after getting burned on this explorer i have to fix it. Can't afford another vehcile. Here is my next series of unfortunate events. I just got done replacing the radiator, water pump, new not rebuilt, fan clutch, upper hose, thermostat, coolant and tempature sending unit. The tempature gauge still goes to the high side of normal then drops down to cold. All the time as it is running. The heat does get hotter coming out of the vents when it raise's and gets cooler when the tempature falls. The garage i took it to said the head gaskets are not blown. My upper hose even collapsed, sucked its self together. Then it filled back out. I watched it do it. Took forever for the tstat to open. Had pressure on the heater hose's and none on the upper radiator hose until the tstat opened. The reason all this was replaced is because the garage said that was my problem, well it did not fix it. Any Ideas?
Thanks All
Thanks All
