davisp
- February 14, 2018
- houston
- 1994 ford explorer
Hello all. I find this forum most helpful but I cant find this problem.
1994 ford explorer. leaving for work this morning and I turn on the headlights and all I have are the park lamps, tail lamps, and brake lights all work. No headlights. I try the high beams, they dont work, but the high beam flasher does work. Check all the fuses cant find anything. I was in a hurry so I was going to run a jumper wire from the park lamps to the headlights as a temp fix.
Well as I unplugged the bulb assembly all the parking lamps went out, but the headlights turned on at that very instant. I checked and the fuse was blown for the parking lamps. So I put a new fuse in and now im back to the original problem. Parking lamps with no headlights. This really baffled me.
Anybody have any suggestions?
Thank you
Thank you
