Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Ford Explorer Sport Trac Forums > 2001-2005 Explorer Sport Trac
Notices
2001-2005 Explorer Sport Trac All questions related to the 2001-2005 Explorer Sport Trac model.
2004: Keyless Entry Code
Reply
Thread Tools
Old 04-04-2007, 10:51 PM   #1
Town Car
Lancaster, CA
2004 Sport Trac XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
US 2004: Keyless Entry Code
HI guys.
One of the things I needed to do with the new XLT was find the Keyless Entry Code. With the help of 'search' on this and some other places I was able to retrieve the code in about 5 minutes. Could have been faster but I was a bit leery prying on the new XLT
Basically it's like this:
  • Pop off the Front Windshield Defroster Vent Cover.
  • From the outside of the XLT look through the windshield at the Keyless Entry Module.
  • The Factory Permanent Code is printed on a sticker, on the top of the module.
Pry up one end of the Defroster Vent Cover. Spring fasteners hold down the side towards you, interlocking tabs hold down the side towards the windshield. With your fingers under the front side, pop each fastener up, all the way across the cab. You may find the center fastener a bitch, so work from both ends.
From the outside looking in you will see the Keyless Entry Module under the Dashboard Panel. The 'engine' side of the Module has a large wire harness connected.
Because the Keyless Module is located under the Dashboard, you will have to look at the top of the module at an angle, maybe even enlist the use of a flashlight.
The five digit number is printed on the top of the module. Other stuff is printed on the labels as well, but the Code Number is the largest font there.
Town Car is offline   Reply With Quote
( Join the Elite Explorers )
Old 08-25-2007, 07:22 PM   #2
Light ShowMaster
Lake Waccamaw
1995 and 2004 XLT's
Vehicle Specs
Quoted: 0 Post(s)
Quote:
Originally Posted by Town Car View Post
HI guys.
  • From the outside of the XLT look through the windshield at the Keyless Entry Moidule.
I Looked at mine and the largest print is only a 4 Digit number (this works for a 04 XLT Explorer also, right? The 4 digits didnt not work 0 3 4 0
Light ShowMaster is offline   Reply With Quote
Old 08-26-2007, 01:20 AM   #3
Town Car
Lancaster, CA
2004 Sport Trac XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Quote:
Hi Light ShowMaster ...
The code is always five numbers; and yes the truck pictured is the Explorer Sport Trac XLT.
I've seen smaller numbers printed, and even stamped on these modules as well.
My Town Car has paint style numbers.
Old 05-15-2009, 05:57 PM   #4
adidas0068
Houston, TX
'02 Explorer Sport Loaded
Vehicle Specs
Quoted: 0 Post(s)
2002-2003 Explorer Sport Keyless Entry Code Location
For anyone wanting to know, the 2002 and 2003 Explorer Sport Keyless entry location is the exact same as the Sport Trac. I tore my 2002 ExSpo apart trying to find this thing. I called my uncle who has a 2003 ExSpo and told him to look in the same place to confirm (even though he bought his new and knew his code). He was able to confirm his 03 ExSpo is in the same exact spot.
Hope this helps everyone with Sports because I tore my whole passenger side back end apart looking for it under the seatbelt. I figured I might as well search for the Sport Trac location since my front end was the same, and sure enough, there it was.
I guess I should have confirmed that it is under the defrost panel by the windshield, passenger side, look in at an angle from the outside as stated in the pictures above, and a flashlight does help.
adidas0068 is offline   Reply With Quote
Old 11-26-2010, 02:32 PM   #5
egls
Vehicle Specs
Quoted: 0 Post(s)
Ford Sport Trac 2003 XLT keypad code
Hi
This is just to confirm this works on a 2003 Sport Trac XLT
Thanks!!
egls is offline   Reply With Quote
Old 04-28-2012, 11:51 AM   #6
Richardneal
Ohio
2004 Ford Sport Trac
Vehicle Specs
Quoted: 0 Post(s)
2004 sport trac key pad???
I have a 2004 sport trac.
Is the code in the same place as yours?
if not do you know where i can find it? Thanks.
Richardneal is offline   Reply With Quote
Old 04-28-2012, 01:53 PM   #7
Town Car
Lancaster, CA
2004 Sport Trac XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Yikes.. I just re-read my post and realized I hadn't mentioned Sport Trac even once.. sorry for that.
YES.. the photos and written instruction above are for Sport Trac, mine's the XLT model but I supposed that's of no importance.
GO FOR IT !!
Old 07-18-2012, 05:06 PM   #8
Aldizzle13
Hayward Ca
03 explorer sport trac
Vehicle Specs
Quoted: 0 Post(s)
2003 xlt
HI guys.
Aldizzle13 is offline   Reply With Quote
Old 04-09-2015, 07:41 PM   #9
Jgoodlove
Iowa
2004 explorer sport trac
Vehicle Specs
Quoted: 0 Post(s)
Dk Exp Thanks
Just purchased an 04 sport trac and needed the code. Great thread! Thanks
Jgoodlove is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
